Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Error while programmatically mergin two models
Error while programmatically mergin two models [message #137000] Tue, 09 June 2009 08:45 Go to next message
Josip Maras is currently offline Josip MarasFriend
Member
Can anyone help me with the following problem:
I'm trying to merge two models in code:
//START CODE
final ResourceSet resourceSet = new ResourceSetImpl();
final EObject model1 = ModelUtils.load
(new File("C:/uml/phpWithAttributes.uml"), resourceSet);
final EObject model2 = ModelUtils.load
(new File("C:/uml/phpWithAttributes1.uml"), resourceSet);
final MatchModel match = MatchService.doMatch
(model1, model2, Collections.<String, Object> emptyMap());
final DiffModel diff = DiffService.doDiff(match, false);
MergeService.merge(new ArrayList<DiffElement>(diff.getOwnedElements()),
true);
//END CODE
I get the following exception:
org.eclipse.emf.compare.diff.metamodel.impl.DiffModelImpl cannot be cast
to org.eclipse.emf.compare.diff.metamodel.ModelInputSnapshot
I would be grateful for any ideas on how to resolve this issue.
Thank you
Re: Error while programmatically mergin two models [message #137064 is a reply to message #137000] Tue, 09 June 2009 16:23 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------090001040904080400070104
Hi Josip,
The error message is pretty straightforward. You cast something you
shouldn't be :).
The line that triggered this is not part of what you copy pasted here.
You have somewhere in your code "(ModelInputSnapshot)aVariable", yet
"aVariable" is of type "DiffModel" and DiffModel is not a subclass of
ModelInputSnapshot ... thus cannot be cast to it.
You can take a look at org.eclipse.emf.compare.examples.standalone to
see an example of how to create and save to disk a ModelInputSnapshot (I
believe this is what you're trying to achieve). If you cannot fix this
error, please copy paste here the line that triggers your exception and
the few lines above it, as well as the few first lines of your exception
so that I can see the line numbers.
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #137084 is a reply to message #137064] Wed, 10 June 2009 06:30 Go to previous messageGo to next message
Member
Hi Laurent, thank you for your response!
Unfortunately, i haven't done any mysterious casting. This is the whole
code.
I'm building a tool to RE php, html and JavaScript into models matching
Connalen's web UML extensions. And these two models (phpWithAttributes.uml
and phpWithAttributes1.uml) are something that my code generates. I'm not
sure but maybe i haven't cleaned up some resources in the model generation
phase - i'll have to check. But my generated models are ok when read from
Eclipse.
The exception is thrown from
true);
Thank you for your help
laurent Goubet wrote:
> Hi Josip,
> shouldn't be :).
> Cheers,
> Laurent Goubet
> Obeo
> Josip Maras a écrit :
>> Hi,
>> //START CODE
>> ArrayList<DiffElement>(diff.getOwnedElements()), true);
>> //END CODE
>> Thank you
Re: Error while programmatically mergin two models [message #137095 is a reply to message #137084] Wed, 10 June 2009 09:22 Go to previous messageGo to next message
--------------070801060300030006050408
Hi Josip,
This might come from a problem within the merge code then ... Could you
copy paste the whole exception stack trace?
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #137106 is a reply to message #137095] Wed, 10 June 2009 09:31 Go to previous messageGo to next message
Member
Hi, here it goes:
to org.eclipse.emf.compare.diff.metamodel.ModelInputSnapshot at
org.eclipse.emf.compare.diff.merge.api.DefaultMerger.findRig htResource(DefaultMerger.java:163)
at
org.eclipse.emf.compare.diff.merge.internal.impl.ModelElemen tChangeLeftTargetMerger.undoInTarget(ModelElementChangeLeftT argetMerger.java:75)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:172)
at
org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:136)
at
org.eclipse.emf.compare.diff.merge.internal.impl.DiffGroupMe rger.undoInTarget(DiffGroupMerger.java:48)
at
at
at
umlGeneratorTest.UmlGeneratorTest.testGenerateUml(UmlGenerat orTest.java:69)
at junit.framework.TestCase.runTest(TestCase.java:168)
at junit.framework.TestCase.runBare(TestCase.java:134)
at junit.framework.TestResult$1.protect(TestResult.java:110)
at junit.framework.TestResult.runProtected(TestResult.java:128)
at junit.framework.TestResult.run(TestResult.java:113)
at junit.framework.TestCase.run(TestCase.java:124)
at junit.framework.TestSuite.runTest(TestSuite.java:232)
at junit.framework.TestSuite.run(TestSuite.java:227)
at
org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38Cla ssRunner.java:91)
at
org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:45)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Re: Error while programmatically mergin two models [message #137118 is a reply to message #137106] Wed, 10 June 2009 09:58 Go to previous messageGo to next message
--------------000802030600070606070901
Josip,
Something I didn't realize before but ... ModelInputSnapshot is a class
that doesn't exist anymore, since 0.9M3 if I am not mistaken. moreover,
DefaultMerger.findRightResource() is deprecated in the latest CVS code.
The 0.9 stream is compatible with the same Eclipse versions as the 0.8
was (see http://wiki.eclipse.org/EMF_Compare#Compatibility ). Can you
try with the latest release of EMF Compare or is there a reason why you
didn't update?
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #137168 is a reply to message #137118] Thu, 11 June 2009 15:56 Go to previous messageGo to next message
Member
Hi Laurent,
I've lost a couple of hours and it seems that i'm doing something wrong
while generating diagrams. If i use the same code on the diagrams i've
created in Eclipse (by hand i add a couple of classes...) everything
works, but if i load my diagrams it crashes with that DiffModelImpl cannot
be cast to ...
But interestingly even my generated diagrams can be compared from the
Eclipse UI. It will be a looong debugging session.
Thank you for everything
> Josip,
> didn't update?
> Laurent Goubet
> Obeo
Re: Error while programmatically mergin two models [message #137505 is a reply to message #137118] Tue, 23 June 2009 08:59 Go to previous messageGo to next message
Member
I've updated to version 1.0, and now i get the following exception:
java.lang.NullPointerException at
org.eclipse.emf.compare.diff.internal.merge.impl.ModelElemen tChangeLeftTargetMerger.undoInTarget(ModelElementChangeLeftT argetMerger.java:75)at
org.eclipse.emf.compare.diff.merge.service.MergeService.doMe rge(MergeService.java:172)at
org.eclipse.emf.compare.diff.merge.service.MergeService.merg e(MergeService.java:136)at
org.eclipse.emf.compare.diff.internal.merge.impl.DiffGroupMe rger.undoInTarget(DiffGroupMerger.java:48)at
Could this issue be happening due to the fact that both uml models are
using the same external profile file defining all stereotypes.
Thank you
Re: Error while programmatically mergin two models [message #137516 is a reply to message #137505] Tue, 23 June 2009 09:26 Go to previous messageGo to next message
--------------060606030203080801060407
Hi Josip,
This exception would mean EMF Compare couldn't find the Resource of your
right model ... Are you using a code as shown in
org.eclipse.emf.compare.examples.standalone.ExampleLauncher or equivalent?
if you are, could you raise a bugzilla with your code and the two models
you compare so that I can try and reproduce?
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #137528 is a reply to message #137516] Tue, 23 June 2009 12:40 Go to previous message
Member
Hi Laurent, thank you for all your help!
I've uploaded the code and the files to:
www.fesb.hr/~jomaras/data/testFiles.rar - one profile, two uml models and
two class diagrams
www.fesb.hr/~jomaras/data/callingCode.java
Thank you
> Hi Josip,
> Laurent Goubet
> Obeo
>> Hi,
>> Thank you
Re: Error while programmatically mergin two models [message #621004 is a reply to message #137000] Tue, 09 June 2009 16:23 Go to previous message
Hi Josip,
shouldn't be :).
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #621006 is a reply to message #137064] Wed, 10 June 2009 06:30 Go to previous message
Member
code.
Eclipse.
true);
> Hi Josip,
> shouldn't be :).
> Cheers,
> Laurent Goubet
> Obeo
>> Hi,
>> //START CODE
>> //END CODE
>> Thank you
Re: Error while programmatically mergin two models [message #621007 is a reply to message #137084] Wed, 10 June 2009 09:22 Go to previous message
Hi Josip,
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #621008 is a reply to message #137095] Wed, 10 June 2009 09:31 Go to previous message
Member
Hi, here it goes:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Error while programmatically mergin two models [message #621009 is a reply to message #137106] Wed, 10 June 2009 09:58 Go to previous message
Josip,
didn't update?
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #621013 is a reply to message #137118] Thu, 11 June 2009 15:56 Go to previous message
Member
Hi Laurent,
be cast to ...
> Josip,
> didn't update?
> Laurent Goubet
> Obeo
Re: Error while programmatically mergin two models [message #621043 is a reply to message #137118] Tue, 23 June 2009 08:59 Go to previous message
Member
Thank you
Re: Error while programmatically mergin two models [message #621044 is a reply to message #137505] Tue, 23 June 2009 09:26 Go to previous message
Hi Josip,
Laurent Goubet
Obeo
Josip Maras a
Re: Error while programmatically mergin two models [message #621045 is a reply to message #137516] Tue, 23 June 2009 12:40 Go to previous message
Member
two class diagrams
Thank you
> Hi Josip,
> Laurent Goubet
> Obeo
>> Hi,
>> Thank you
Previous Topic:How to add EMF Index Plugins?
Next Topic:How to add EMF Index Plugins?
Current Time: Wed Jan 22 09:17:45 GMT 2025
Powered by FUDForum. Page generated in 0.04677 seconds
