Be unable to load class [message #136826] |
Sun, 25 March 2007 21:35  |
Originally posted by: lihailin.ceclipse.org
hi,all
i had added to the VE plug-in. but when i created a "visual class" or
RCP's "View Visual Class" , it throws an error:
"The selected wizard could not be started.
Reason:
Plug-in org.eclipse.ve.swt was unable to load class
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard. "
what the problem was? Counld Somebody give me any idea? appreciate your
help.
thanks . Allen
Re: Be unable to load class [message #136960 is a reply to message #136929] |
Tue, 27 March 2007 09:22  |
You didn't tell me what versions you had. Your best bet is to use
Callisto update site instead of using zip files. Callisto works best by
making sure you have installed the correct versions of code.
allen wrote:
> thanks.i added the VE first, added GEF after it.May be it was the
> problem. let me reset the Eclipse.
Rich Kulp
Re: Be unable to load class [message #615158 is a reply to message #136826] |
Mon, 26 March 2007 09:59  |
What versions of Eclipse, GEF, EMF, and VE do you have installed?
Also, more of the .log would be helpful. There's probably another
exception trace with the real error.
Rich Kulp
Re: Be unable to load class [message #615167 is a reply to message #136929] |
Rich Kulp
FUDForum. Page generated in 0.30129 seconds
