Re: Rap (jetty server) ---> https connection how to [message #136652 is a reply to message #136544] |
Wed, 17 June 2009 17:41 |
The RAP FAQ has a section on using HTTPS with Jetty:
http://wiki.eclipse.org/RAP/FAQ#How_can_I_test_my_applicatio n_with_HTTPS.3F
Ralf
vijay wrote:
> Hi guys,
> my problem i have an RCP application which connects to a https app
> server at port 8001
> I have converted this RCP app to RAP app my making all the dependency
> changes and commenting all the incompatible code(SWT)
> Now the problem is i connect to the jetty server using http and the
> jetty connects to the app server using https and says certificate not
> found although in muy machine
> the certificate is installed(the jetty is running on my machine)
> How can i resolve this issue....
> and also what if i want to connect to jtty using https and want to
> forward the same certificate info to the https app server???
> any help in terms of giving direction via links will also be appreciated...
FUDForum. Page generated in 0.03474 seconds
