Re: Eclipse Console showing old exceptions [message #964943 is a reply to message #963850] |
Tue, 30 October 2012 22:53 |
Daniel Stevenson Messages: 3 Registered: October 2012 |
No, if I clear the console, the next time I run the application, they all appear again.
It is really odd. They certainly are not current exceptions, as they have been resolved.
It is like it is remembering every exception is has ever hit, and then each time I run the application it prints this list out in the console, appending the current one on to the end of the list (if there was an exception of course). So with it appending the exceptions, the list is getting rather long..
for example, if i have a NullPointerException, that i didn't resolve, but ran and stopped my application 5 times, in the console, after the 5th time, before the application runs, it would print out:
adding another one everytime i run the application without fixing the problem... as soon as i fix the problem, it will stop appending it to the end, but will still print out the above... then say i had an SQL Exception it would append that to the end, as:
java.sql.SQLException
so, you see this list is growing and growing, and added to everytime i run the application when it has an exception, but is printed out to the console every time. All the listed exceptions have been resolved, they are definitely not current exceptions... just a list of old ones that is being appended to that gets printed to the console everytime i run the application
the only affect it seems to be having is that it makes the startup time for the application slow as it prints this list out everytime before it runs.. and also the console scrollbar is getting smaller by the day as this list grows!
I have googled my A** off and haven't found anyone with this issue happening
Daniel
[Updated on: Tue, 30 October 2012 22:56] Report message to a moderator
FUDForum. Page generated in 0.07899 seconds
