Home » Eclipse Projects » Remote Application Platform (RAP) » Bug in Table.getColumnOrder() when after moving a column
Bug in Table.getColumnOrder() when after moving a column [message #136507] |
Tue, 16 June 2009 17:03  |
Loïc Bertholet Messages: 57 Registered: July 2009 |
Member |
Hi all,
When I drag and drop a column, the call of Table.getColumnOrder() returns
a wrong array when the first column of the table are hidden thanks to a
scroll bar which is outside the table.
It seems that the new position of the moved column is calculated without
these hidden column.
Example : I have 10 columns, the 5 first are hidden, the other one are
visible.
Order is : [0,1,2,3,4,5,6,7,8,9]
If I move 9 before 7 I should have [0,1,2,3,4,5,6,9,7,8]
And I obtain [0,1,9,2,3,4,5,6,7,8]
If needed, I will try to extract a snippet from my code, just ask.
Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136569 is a reply to message #136507] |
Wed, 17 June 2009 13:30   |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Loïc,
with the latest version from CVS I cannot reproduce what you
describe. Which version are you using?
Rüdiger
Loïc Bertholet wrote:
> Hi all,
> returns a wrong array when the first column of the table are hidden
> thanks to a scroll bar which is outside the table.
> visible.
> Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136606 is a reply to message #136569] |
Wed, 17 June 2009 15:14   |
Member |
Hi Rüdiger,
I'm also using the latest version from CVS.
It is happening on FF3 and IE7.
And it only happens when some TableColumns of the beginning are hidden by
a scroll bar which is not the Table one : my Table does not have scroll
bar.
It can be the scroll bar of the ScrolledComposite or the View which
contained the Table.
I will try to provide a snippet as soon as possible.
Loïc
Rüdiger Herrmann wrote:
> Loïc,
> Cheers,
> Rüdiger
>> Hi all,
>> visible.
>> Thanks,
>> Loïc
Re: Bug in Table.getColumnOrder() when after moving a column [message #136618 is a reply to message #136606] |
Wed, 17 June 2009 15:17   |
I think the ScrolledComposite was the thing missing.
Feel free to file a bugzilla and attach the code there.
> Hi Rüdiger,
> by a scroll bar which is not the Table one : my Table does not have
> scroll bar.
> Loïc
>> Loïc,
>> with the latest version from CVS I cannot reproduce what you describe.
>> Cheers,
>> Rüdiger
>>> Hi all,
>>> without these hidden column.
>>> are visible.
>>> Thanks,
>>> Loïc
Current Time: Sat Mar 25 12:15:41 GMT 2023
Powered by FUDForum. Page generated in 0.01491 seconds
