Home » Eclipse Projects » EclipseLink » EntityManagerFactory (Eclipselink RCP) return NullPointerException
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #965764 is a reply to message #964494] |
Wed, 31 October 2012 13:41 |
Azi Azwady Jamaludin Messages: 10 Registered: October 2012 |
Hi Shaun,
I've just tried Gemini JPA. Also changing the MamsysEntityManagerFactory properties as attach but the result still the same.
!STACK 0
at org.eclipse.mamsysdispose.model.connection.MamsysEntityManagerFactory.createEntityManager(MamsysEntityManagerFactory.java:52)
at org.eclipse.mamsysdispose.model.CreateCaseModel.<init>(CreateCaseModel.java:24)
at org.eclipse.mamsysdispose.views.viewparts.NewCaseView$2$1.run(NewCaseView.java:162)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Also put the driver (mysql-connector-java-5.1.22-bin.jar) in Bundle-Classpath. (JPA Project that been converted into Plug-in project)
Something is missing I quest
[Updated on: Wed, 31 October 2012 16:09] Report message to a moderator
Re: EntityManagerFactory (Eclipselink RCP) return NullPointerException [message #972764 is a reply to message #972284] |
Mon, 05 November 2012 22:06 |
Hi Shaun,
I think there is a connection but i'm sure something needs to be configured. I attach all the stack trace here:
Hello World!!
[EL Config]: metadata: 2012-11-06 05:42:12.781--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainList] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.811--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.812--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field createCase] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.813--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.815--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.873--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprDocs] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.889--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.889--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.89--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field initialReceives] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.89--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.891--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.892--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field registerUser] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:12.892--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Process] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.893--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.893--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa17] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field approQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.894--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.895--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.895--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.896--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.896--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Approval] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.897--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field processes] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:12.899--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approval] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Approval.
[EL Config]: metadata: 2012-11-06 05:42:12.9--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.9--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa172] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.901--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa173] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.901--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.902--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field createCases] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.902--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.903--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.903--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field appliQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.907--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field appliQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.915--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.917--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.918--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.918--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.919--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainListPK] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:12.944--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MainList.
[EL Config]: metadata: 2012-11-06 05:42:12.946--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MAINLIST.
[EL Config]: metadata: 2012-11-06 05:42:12.966--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [postapprDoc_idfinalDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.967--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [createCase_idcaseID] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.967--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_idinitialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.971--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.972--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: POSTAPPRQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.972--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_Letterdate] is being defaulted to: FINALQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.975--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_ref] is being defaulted to: FINALQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.975--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.976--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.976--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: APPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_ref] is being defaulted to: APPLIQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idappliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.977--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_Letterdate] is being defaulted to: APPLIQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CREATECASE.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idcaseID] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.978--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [logdate] is being defaulted to: LOGDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [officeLocation] is being defaulted to: OFFICELOCATION.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [department] is being defaulted to: DEPARTMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.979--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [state] is being defaulted to: STATE.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: Process.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: PROCESS.
[EL Config]: metadata: 2012-11-06 05:42:12.98--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idprocess] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processReceive_date] is being defaulted to: PROCESSRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_date] is being defaulted to: PROCESSLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.981--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_ref] is being defaulted to: PROCESSLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: APPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_Letterdate] is being defaulted to: APPROQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:12.982--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_ref] is being defaulted to: APPROQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: POSTAPPRDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.983--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_ref] is being defaulted to: FINALDOCLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocReceive_date] is being defaulted to: FINALDOCRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.984--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_date] is being defaulted to: FINALDOCLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA19] is being defaulted to: KEWPA19.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA18] is being defaulted to: KEWPA18.
[EL Config]: metadata: 2012-11-06 05:42:12.985--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: Approval.
[EL Config]: metadata: 2012-11-06 05:42:12.988--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: APPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toDept] is being defaulted to: LETTERDATE_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toTry] is being defaulted to: LETTERDATE_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_toDept] is being defaulted to: REFAPPR_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:12.989--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [month_Appr] is being defaulted to: MONTH_APPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refletter_toTry] is being defaulted to: REFLETTER_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [year_Appr] is being defaulted to: YEAR_APPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_Tryappr] is being defaulted to: LETTERDATE_TRYAPPR.
[EL Config]: metadata: 2012-11-06 05:42:12.99--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_frTry] is being defaulted to: REFAPPR_FRTRY.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.991--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [deptshName] is being defaulted to: DEPTSHNAME.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:12.992--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: REGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idregisterUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [password] is being defaulted to: PASSWORD.
[EL Config]: metadata: 2012-11-06 05:42:12.993--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: INITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_date] is being defaulted to: INITIALRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.994--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idinitialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_date] is being defaulted to: INITIALLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [dateTo_inspect] is being defaulted to: DATETO_INSPECT.
[EL Config]: metadata: 2012-11-06 05:42:12.995--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_ref] is being defaulted to: INITIALLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.996--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_2] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:12.997--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_3] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.053--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [process] is being defaulted to: PROCESS_IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field initialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.054--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [initialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field createCase] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [createCase] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.055--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [postapprDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field initialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field registerUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.056--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.061--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [kewPa17] is being defaulted to: KEWPA17_IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.061--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field postapprQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [postapprQuery] is being defaulted to: POSTAPPRQUERY_IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field approQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.062--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [approQuery] is being defaulted to: APPROQUERY_IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.063--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field approval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.063--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa172] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field kewPa173] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field appliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.064--ServerSession(1257680412)--Thread(Thread[Worker-0,5,main])--The foreign key column name for the mapping element [appliQuery] is being defaulted to: APPLIQUERY_IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.098--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainList] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.098--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field createCase] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.099--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.1--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprDoc] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.103--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprDocs] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.103--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.104--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field initialReceive] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.104--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field initialReceives] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.105--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.105--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.11--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field registerUser] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:13.11--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Process] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa17] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.111--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field approQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field process] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.112--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field postapprQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.113--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field postapprQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.114--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.Approval] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.114--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field processes] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Process.
[EL Config]: metadata: 2012-11-06 05:42:13.115--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approval] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.Approval.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field approQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa172] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.116--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field kewPa173] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.117--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.117--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field createCases] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field mainLists] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.118--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the many to one mapping element [field appliQuery] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field appliQueries] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.12--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.121--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.121--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The target entity (reference) class for the one to many mapping element [field kewPa17s] is being defaulted to: class org.eclipse.mamsysdispose.model.entity.KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The access type for the persistent class [class org.eclipse.mamsysdispose.model.entity.MainListPK] is set to [FIELD].
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MainList.
[EL Config]: metadata: 2012-11-06 05:42:13.122--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.MainList] is being defaulted to: MAINLIST.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [postapprDoc_idfinalDoc] is being defaulted to: POSTAPPRDOC_IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [createCase_idcaseID] is being defaulted to: CREATECASE_IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_idinitialReceive] is being defaulted to: INITIALRECEIVE_IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.127--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: PostapprQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprQuery] is being defaulted to: POSTAPPRQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_Letterdate] is being defaulted to: FINALQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finalQuery_ref] is being defaulted to: FINALQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalQuery] is being defaulted to: IDFINALQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.128--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: AppliQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.AppliQuery] is being defaulted to: APPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_ref] is being defaulted to: APPLIQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idappliQuery] is being defaulted to: IDAPPLIQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.129--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [appliQuery_Letterdate] is being defaulted to: APPLIQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CreateCase.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.CreateCase] is being defaulted to: CREATECASE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idcaseID] is being defaulted to: IDCASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [logdate] is being defaulted to: LOGDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.13--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [officeLocation] is being defaulted to: OFFICELOCATION.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [department] is being defaulted to: DEPARTMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [state] is being defaulted to: STATE.
[EL Config]: metadata: 2012-11-06 05:42:13.131--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: Process.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Process] is being defaulted to: PROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idprocess] is being defaulted to: IDPROCESS.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.132--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processReceive_date] is being defaulted to: PROCESSRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_date] is being defaulted to: PROCESSLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [processLetter_ref] is being defaulted to: PROCESSLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: ApproQuery.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.ApproQuery] is being defaulted to: APPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.133--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_Letterdate] is being defaulted to: APPROQUERY_LETTERDATE.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [approQuery_ref] is being defaulted to: APPROQUERY_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproQuery] is being defaulted to: IDAPPROQUERY.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: PostapprDoc.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.PostapprDoc] is being defaulted to: POSTAPPRDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.134--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idfinalDoc] is being defaulted to: IDFINALDOC.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_ref] is being defaulted to: FINALDOCLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocReceive_date] is being defaulted to: FINALDOCRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.135--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [finaldocLetter_date] is being defaulted to: FINALDOCLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA19] is being defaulted to: KEWPA19.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [kewPA18] is being defaulted to: KEWPA18.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: Approval.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.Approval] is being defaulted to: APPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toDept] is being defaulted to: LETTERDATE_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:13.136--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_toTry] is being defaulted to: LETTERDATE_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_toDept] is being defaulted to: REFAPPR_TODEPT.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [month_Appr] is being defaulted to: MONTH_APPR.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refletter_toTry] is being defaulted to: REFLETTER_TOTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.137--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idapproval] is being defaulted to: IDAPPROVAL.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [year_Appr] is being defaulted to: YEAR_APPR.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [letterdate_Tryappr] is being defaulted to: LETTERDATE_TRYAPPR.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [refappr_frTry] is being defaulted to: REFAPPR_FRTRY.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KewPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.138--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17] is being defaulted to: KEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17] is being defaulted to: IDKEWPA17.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [deptshName] is being defaulted to: DEPTSHNAME.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [attachment] is being defaulted to: ATTACHMENT.
[EL Config]: metadata: 2012-11-06 05:42:13.139--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: RegisterUser.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.RegisterUser] is being defaulted to: REGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idregisterUser] is being defaulted to: IDREGISTERUSER.
[EL Config]: metadata: 2012-11-06 05:42:13.14--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [password] is being defaulted to: PASSWORD.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: InitialReceive.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.InitialReceive] is being defaulted to: INITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialReceive_date] is being defaulted to: INITIALRECEIVE_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.141--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idinitialReceive] is being defaulted to: IDINITIALRECEIVE.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_date] is being defaulted to: INITIALLETTER_DATE.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [fullicNo] is being defaulted to: FULLICNO.
[EL Config]: metadata: 2012-11-06 05:42:13.142--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [dateTo_inspect] is being defaulted to: DATETO_INSPECT.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [caseID] is being defaulted to: CASEID.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [initialLetter_ref] is being defaulted to: INITIALLETTER_REF.
[EL Config]: metadata: 2012-11-06 05:42:13.143--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KewPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_2] is being defaulted to: KEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_2] is being defaulted to: IDKEWPA17_2.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The alias name for the entity class [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KewPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.144--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The table name for entity [class org.eclipse.mamsysdispose.model.entity.KewPA17_3] is being defaulted to: KEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.145--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The column name for element [idkewPA17_3] is being defaulted to: IDKEWPA17_3.
[EL Config]: metadata: 2012-11-06 05:42:13.145--ServerSession(2100855933)--Thread(Thread[Worker-0,5,main])--The primary key column name for the mapping element [field process] is being
[Updated on: Mon, 05 November 2012 22:12] Report message to a moderator
Current Time: Thu Mar 28 22:37:06 GMT 2024
Powered by FUDForum. Page generated in 0.02991 seconds
