Re: Unable to change perspective using SWTbot and Juno [message #981363 is a reply to message #962777] |
Mon, 12 November 2012 11:00 |
On 10/29/2012 11:19 AM, Anitha Mising name wrote:
> The exact line is while it is trying to access the menu. Do let me know
> if there is any change i need to make, to make the test case work for Juno.
Which menu?
Is this menu actually here? Eclipse 4.2 has some refactoring in the
Welcome menu IIRC, so maybe you're simply missing the plugin responsible
of displaying it.
Do you use Linux? Do you have a working window manager on the DISPLAY
you're using? I saw some issues like this one before because of usage of
twm or other bad window managers...
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Unable to change perspective using SWTbot and Juno [message #987816 is a reply to message #981363] |
Wed, 28 November 2012 09:31 |
Anitha Mising name Messages: 28 Registered: February 2010 |
> Which menu?
It's the basic Windows menu that is used to access perspectives as in the case of code below. This menu comes with Eclipse Juno 4.2.
bot.menu("Window")
> of displaying it.
All the plugins are available.
No, i am Windows user. Also i found hitting this issue again when i tried to create some projects and build using 'Build All' option. I am unable to access the menu 'Project'.
bot.menu("Project").menu("Build All").click();
Even this throws the same WidgetNotFoundException.
[Updated on: Wed, 28 November 2012 09:33] Report message to a moderator
FUDForum. Page generated in 0.02396 seconds
