Home » Newcomers » Newcomers » My Perspective changes - is this normal?
icon5.gif  My Perspective changes - is this normal? [message #962030] Sun, 28 October 2012 20:26 Go to next message
Larry Parker is currently offline Larry ParkerFriend
I have a perspective saved and periodically after running projects, it changes. Like the Outline window is gone. I go from Debug and back to my saved perspective and it stays gone. This is one of the things that eclipse does that is annoying. What's the use in saving a custom perspective if eclipse changes it all the time? Is this normal behavior for the Classic version?
I've had this happen years ago when I ran other versions too.
Re: My Perspective changes - is this normal? [message #962496 is a reply to message #962030] Mon, 29 October 2012 05:20 Go to previous messageGo to next message
Larry,
No, that's not normal. A bugzilla with steps to reproduce the problem
would be great! (I've never seen this happen.)
Ed Merks
Re: My Perspective changes - is this normal? [message #962939 is a reply to message #962496] Mon, 29 October 2012 12:53 Go to previous messageGo to next message
I didn't expect to see that you have never seen it happen. Every time I have started to use eclipse through the years, it happens all the time and it's frustrating. I must be doing something wrong then. However, all I do is run samples and skeleton java code and when they end, the perspective changed. I really didn't do anything fancy. I seem to be jinxed with eclipse.
Thank you for your reply. Razz
[Updated on: Mon, 29 October 2012 13:11]
Report message to a moderator
Re: My Perspective changes - is this normal? [message #963013 is a reply to message #962939] Mon, 29 October 2012 14:00 Go to previous messageGo to next message
David Williams is currently offline David WilliamsFriend
> Thank you for your reply. :p
I don't see it often, once a month or so, and its always after I've been
"flying around" clicking lots of things, hitting lots of keys, so figure
I just some how accidentally hit "cntl-something-or-other" ... but I
always just use "reset perspective" and all goes back go normal
(including what ever changes I had customized into that perspective".
So, my point is, if you open a bug, be sure to say if "reset" is not
working as you expect, or if your changes to customization are not being
saved across reset, or whatever.
Good luck,
Re: My Perspective changes - is this normal? [message #963024 is a reply to message #962939] Mon, 29 October 2012 14:07 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Wow, I can say that in 6-7 years of Eclipse use, I've never seen this
either. (I've always downloaded Eclipse IDE for Java EE Developers.)
Bad karma, man.
Re: My Perspective changes - is this normal? [message #963186 is a reply to message #963024] Mon, 29 October 2012 16:25 Go to previous messageGo to next message
Russell Bateman wrote on Mon, 29 October 2012 07:07
Bad karma, man.
Funny. Yeah, I've felt jinxed alright. I also use intelliJ and I prefer that IDE, but too many books and also code on the Internet are done with eclipse.
[Updated on: Mon, 29 October 2012 16:29]
Re: My Perspective changes - is this normal? [message #963254 is a reply to message #963024] Mon, 29 October 2012 17:24 Go to previous message
Bad karma, man.
I installed JEE instead of using Classic and it runs much faster. The plugins installed smoother too. Maybe this will help.
Previous Topic:Font of hover
Next Topic:Best eclipse version for Android development under Windows 7 64 bits
Current Time: Tue May 24 19:35:45 GMT 2022
Powered by FUDForum. Page generated in 0.03087 seconds
