Home » Eclipse Projects » Remote Application Platform (RAP) » webappBuilder: binary cycles?
webappBuilder: binary cycles? [message #134958] Thu, 04 June 2009 20:10 Go to next message
Kristian Rink is currently offline Kristian RinkFriend
Member
Folks;
using the webappBuilder.xml script to package our application to a .war
file, I thought I so far have seen everything... until just a few moments
ago, after throwing in some additional bundles to our application, the
dreaded "A cycle was detected when generating the classpath..." message
appeared when trying to run the pde:exportFeatures task. Reading through
[1], I see that Eclipse 3.5 has a way of dealing with this, unfortunately I
haven't yet found out how to make this work with webappBuilder.xml. Can
someone enlighten me about this?
And, adding to this again, is there a more "reliable" way of building a .war
file than that? Right now, despite RAP development in Eclipse is pretty
straightforward, I usually do spend an amount of time way too long in order
to get everything right to make webappBuilder.xml work again given, i.e.,
bundles have been added or removed. Can I "abuse" PDE Build to make a RAP
application a .war file? Is this documented anywhere, if so?
Thanks in advance and best regards,
Kristian
PS: Please cc' me in case of any replies as I am out-of-office (thus away
from NNTP most of the time... :( ).
[1] http://eclipsesource.com/blogs/2008/10/28/tip-pde-build-and- binary-cycles/
Re: webappBuilder: binary cycles? [message #135231 is a reply to message #134958] Fri, 05 June 2009 17:27 Go to previous messageGo to next message
Rüdiger Herrmann is currently offline Rüdiger HerrmannFriend
Kristian Rink wrote:
> Folks;
You may ask the blog author as he probably knows best how to have
pdeExportFeatures ignore those dependencies.
We use PDE Build to build the online demos. As a starting point you
could use the "org.eclipse.rap.releng.warbuild" project, that can be
found in CVS. There is not so much "abuse" except that the result is
packed into a war file.
> Kristian
Re: webappBuilder: binary cycles? [message #135369 is a reply to message #135231] Mon, 08 June 2009 06:48 Go to previous messageGo to next message
Member
Hi Rüdiger, *;
.... and, first off, thanks a bunch for your comments on that.
Done so. Gonna wait and see whether some enlightenment is to be gained from
that...
Well, I already by now played with this a couple of times, but never so far
succeed, instead failing in various ways:
- Not sure this works flawlessly with Eclipse 3.5Mx builds, simply replacing
plugin version strings that seem to relate to 3.4 didn't work out of the box.
- Running this seems sort of "black art" at the moment: While working on a
RAP based application, it seems the launcher provided with releng.warbuild
doesn't work at all. Working in a "clean" workspace, having the stock
Eclipse distribution set to be target build platform, it seems to work
though it, to some degree, seems to depend upon other projects pulled off
CVS to the local workspace (releng.tooling?), while it's not completely
clear which projects are required for that.
- In the build.properties files of releng.warbuild and releng.tooling, I see
a lot of entries like "<buildType-set-by-system-property>" in places in
which, doing an RCP PDE Build, I would have put actual values. They don't,
however (at least looking at the launcher provided with releng.warbuild)
seem to be set anywhere, at least it's not clear where.
- As a load of relevant information seem(?) to be hard-wired in the launch
configuration rather than the properties / build scripts, so running this as
a headless PDE build also seems not possible in such a straightforward fashion.
My last try, so far, was to again start over with a clean workspace, try to
check out all the projects that seemed relevant, run the releng.warbuild
launcher, see it check out a whole load of additional CVS projects to
eventually fail like this:
BUILD FAILED
/home/kr/kontext/runtime/devtools/eclipse3.5/plugins/org.ecl ipse.pde.build_3.5.0.v20090521-1730/scripts/build.xml:24:
The following error occurred while executing this line:
/home/kr/kontext/runtime/devtools/eclipse3.5/plugins/org.ecl ipse.pde.build_3.5.0.v20090521-1730/scripts/build.xml:72:
/home/kr/workspaces/rap-cvs-clean/org.eclipse.rap.releng.too ling/customTargets.xml:68:
Warning: Could not find file
/home/kr/kontext/runtime/devtools/eclipse3.5/plugins/org.ecl ipse.pde.build_3.5.0.v20090521-1730/scripts/${rapTarget}
to copy.
This is somewhat confusing, and it's a pretty sad situation actually: While
RAP in itself is a pretty great technology to use and to deal with, but the
way to get an actual application out and deployed still leaves a bit to be
improved. :(
Cheers & all the best,
Kristian
Re: webappBuilder: binary cycles? [message #135624 is a reply to message #135369] Tue, 09 June 2009 20:34 Go to previous messageGo to next message
Kristian,
RAP is based on Equinox and adapts RCP. As a consequence it
"inherits" its build system that is maintained by the "releng
project" [1]. Please see there for a general introduction and
documentation or to report enhancements request.
It is out of scope for RAP to provide a general purpose war build
system.
Please also see my comments below.
HTH
Rüdiger
[1] http://www.eclipse.org/eclipse/platform-releng/index.php
> Hi Rüdiger, *;
> that...
We are running the releng.warbuild on Eclipse 3.4. for other
versions I don't know.
Right, releng.warbuild re-uses the map file from releng. I am not
aware that there is a dependency on releng.tooling.
The launch config that comes with the warbuild sets the value "N"
for the buildType. Not sure what is going wrong here.
Alternatively you could have a look at the shell scripts in
....releng/scrips to run the build.
As said in my previous post, you may find this useful as a starting
point or template and adjust it to fit your needs. It is not meant
to be a general RAP build system.
> BUILD FAILED
> to copy.
Seeing the ${rapTarget} property, it looks like you are running the
tooling build, this is probably not what you actually want.
> improved. :(
> Kristian
Re: webappBuilder: binary cycles? [message #135637 is a reply to message #135624] Wed, 10 June 2009 06:23 Go to previous message
Member
Hi Rüdiger;
and first off, thanks a bunch for your statements and help on that, really
appreciated.
> RAP is based on Equinox and adapts RCP. As a consequence it "inherits"
> its build system that is maintained by the "releng project" [1].
From the RCP-RAP and single-sourcing approach, this seems generally
reasonable. However I wonder, by then, how RAP applications in "productive"
environments are used at the moment? Building, deploying a "normal" Eclipse
Platform application, just containing an RAP not RCP UI, moving this stuff
to the server and re-starting the binary there? I was thinking about this as
well but it seems pretty clumsy compared to, say, deploying a .war file to
some Java EE container...
> Please see there for a general introduction and documentation or to report
> It is out of scope for RAP to provide a general purpose war build system.
Okay, I will have a look at this then. Pardon me if I am all too "demanding"
on that, I just supposed that, given that on one side the RAP tooling is
pretty sophisticated already, and on the other side something like .war
deployment is pretty much "the way to go" in server side Java, I thought of
this as something utterly obvious I just so far missed to figure out how to
get it done. At the moment, I am still using the webappBuilder.xml and the
feature containing it, manually exporting the bundles to the "build/" folder
using the IDE tooling (as the binary cycles issue still doesn't work the way
I want it) and manually packing the .war file. This is not really a nice
procedure, but it works...
> Right, releng.warbuild re-uses the map file from releng. I am not aware
Well, I don't really "know". I just figured out that, "just" checking out
and trying to run releng.warbuild, the warbuild launch configuration stops
rather early. Checking out releng.tooling as well makes it terminate a
little later. As I am not completely sure how the RAP build process and the
warbuild launcher actually works, it's all "trial-and-error" at the moment. :(
> The launch config that comes with the warbuild sets the value "N" for
Maybe blame it to the "trial-and-error" approach again, at the moment I'm
walking the fog, trying to figure out how the pieces go together and what it
takes to make things "really" work...
I will do that, thanks a bunch for the pointer and, overally, your patience
in that. :)
Kristian
Previous Topic:image + war
Next Topic:Possibility to remove H_SCROLL and V_SCROLL from Tables
Current Time: Mon Jun 05 14:54:54 GMT 2023
Powered by FUDForum. Page generated in 0.02538 seconds
