Script task doesn't display Script Format dropdown [message #957968] |
Thu, 25 October 2012 16:41 |
Richard Morgan Messages: 2 Registered: October 2012 |
Updated both an Eclipse Indigo and Eclipse Juno install using the BPMN site http://download.eclipse.org/bpmn2-modeler/site/ and all appeared to work correctly.
However, when I insert a Script task into a bpmn process diagram, then open the properties dialog, the script format dropdown doesn't exist, instead I see a label that says "Script Format" followed by "text/xml". My coworker gets a dropdown menu there that offers Java and MVEL. How come I don't get those choices?
Also, the place where there should be a drop down isn't even outlined to make it appear like a data entry text box, it just looks like the words are part of the label, but I can click there and change the value. Same goes for the script box beneath it. I just see a label that says "Script" and I have to know that if I click to the right of it somewhere, I can start typing. There's no visual clue.
I assume there's an incompatibility with other Indigo/Juno components like EMF or GEF, but no amount of updating those things fixes the problem.
Re: Script task doesn't display Script Format dropdown [message #964581 is a reply to message #964438] |
Tue, 30 October 2012 16:30 |
Kewl. This seems to be confusing a lot of users so I've added a New File Wizard to the "BPMN2" category named "New jBPM Process File". This wizard also sets the project to use the jBPM5 runtime onfiguration. This new feature will be available in the next service release.
Thanks for your continued testing!
Bob
FUDForum. Page generated in 0.04353 seconds
