Re: Eclipse compilation without packages and project creation [message #959169 is a reply to message #957867] |
Fri, 26 October 2012 13:56 |
On 10/26/2012 07:43 AM, geek bits wrote:
> Hi all !
> This is my first post @ Eclipse and I am new to Eclipse. I am a beginner
> in Java. I had been using Edit Plus . I create .java files in Edit Plus
> and compile and run in the command prompt. I find this very convenient.
> Though the same can be done in Eclipse too, but by default, I need to
> create a New Project and then Package and Class file and then creating
> .java files. Compiling and running can be done in Eclipse itself or in
> the command prompt.
> I do not need project and packages as of now as I am beginner , I am
> trying to get comfortable in java by trying with lot of basic programs
> in java for which packages and projects not needed.
> My question is : Can we create .java files without creating project and
> packages ( as I used to do in Edit Plus ) and save it and compile it in
> command prompt ?
> Thanks & Regards
> Geek Bits
The short answer is no. Eclipse organizes things into projects. You're
going to find the concept easier after you've done it. You can create a
single project and put all your sample code inside it to run and debug.
You'll see, it will save you a lot of time.
Use the simple Java Project.
Use this tutorial if you want no-brainer, easy to learn instruction:
http://www.vogella.com/articles/Eclipse/article.html
See
FUDForum. Page generated in 0.04045 seconds
