Home » Archived » Buckminster » version range substitution in MANIFEST.MF
version range substitution in MANIFEST.MF [message #956921] Wed, 24 October 2012 22:28 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
I noted that when I create a p2.site with buckminster action, if a
bundle in its MANIFEST.MF has a lowerbound then in the MANIFEST.MF of
the generated jar that version range is kept, but if there is no version
range in the original MANIFEST.MF, then in the generated MANIFEST.MF a
brand new version range is automatically created:
- lowerbound: the version of the required bundle as in the current
target platform, say 1.x.y
- upperbound: the next major version, thus 2.0.0 in this example
is this the normal behavior coming from p2 or somewhere else?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: version range substitution in MANIFEST.MF [message #957674 is a reply to message #956921] Thu, 25 October 2012 12:00 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
This is the default behaviour. The behaviour can be controlled using
properties. You can find more info on the documentation issue here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309147#c2
We have a long backlog on documentation issues currently.
- thomas
On 2012-10-25 00:28, Lorenzo Bettini wrote:
> Hi
> thanks in advance
> Lorenzo
Re: version range substitution in MANIFEST.MF [message #960465 is a reply to message #957674] Sat, 27 October 2012 14:03 Go to previous message
Thanks Thomas
This concerns only required bundles where I haven't made no version
range explicitly, right?
Please, let me check whether I understand:
*pde.match.rule.bundle*
Defines the match rule used for the "Require-Bundle" header.
Default: compatible
*pde.match.rule.bundle.lower*
Defines an additional rule for the lower bound of the ranges generated
Default: equivalent
"The lower match rule enables fine grained control of the lower bound.
This only makes sense if it is set to a rule that is more stringent then
the setting for the main match rule."
since the "lower" rule is more stringent by default, then the generated
ranges will be
1.2.3.abc -> [1.2.0,2.0.0)
right?
However, 1.2.3.abc refers to the version in the target platform.
do you mean that the bucky book is becoming obsolete? Can I help in
some way?
cheers
Lorenzo
> - thomas
>> Hi
>> thanks in advance
>> Lorenzo
Previous Topic:Building product for Eclipse 3.7+
Next Topic:[solved] Can't install emma.headless
Current Time: Thu Aug 22 07:30:59 GMT 2019
Powered by FUDForum. Page generated in 0.01807 seconds
