Re: Label text being cutoff when resizing browser or chaging zoom level of browser [message #959404 is a reply to message #956765] |
Fri, 26 October 2012 17:36  |
Tim Buschtoens Messages: 396 Registered: July 2009 |
Hi.
Your problems should not be directly related to SWT layouting. This
glitch is a result of rounding errors by the browser. It is known to
happen when zooming on runtime[1]. However, if the zoom level is 100%
from the start and isn't changed, this should NOT happen. If a simple
resize of the browser results in this, it's likely a bug that should be
reported.
If you can give a snippet or example project to reproduce it, i will
have a look at it.
Greetings,
Tim
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=351218
Am 24.10.2012 21:47, schrieb George R Malary:
> I have a constant problem of labels being cut off. The final letter is
> either partly showing, or sometimes the whole label is showing only
> half. This happens sometimes on normal workflow, switching views,
> perspectives, but it happens consistently when zooming in and out with
> the browser, or also when resizing the browser. I have played with
> calling pack() on labels, or layout'ing composites.
> I wonder if this is the only way to handle this, and if there is a way
> to handle this for the whole application. Or do I have to add a
> listener to re-layout the whole application on workbench resize, or zoom?
> Any advice would be greatly appreciated.
Tim Buschtöns
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03827 seconds
