Re: xmi:id get lost when saving Resource [message #956408 is a reply to message #956366] |
Wed, 24 October 2012 13:34 |
Ed Willink Messages: 7655 Registered: July 2009 |
Yes. It seems like a Resource without the useUIds is in use.
Using UMLResourcesUtil.init() is to all intents and purposes mandatory
to get UML registrations correct in a standalone context.
Ed Willink
On 24/10/2012 14:55, Ed Merks wrote:
> Ed,
> It seems likely that he's not registered the UML resource factories
> correctly. There's some UML utility that does that for stand alone
> applications, right?
> On 24/10/2012 1:56 PM, Ed Willink wrote:
>> Hi
>> You seem to have omitted your question, except from the title.
>> Perhaps you are encountering the lack of xmi:id stability in
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=313951.
>> Regards
>> Ed Willink
>> On 24/10/2012 12:43, Jens Bürger wrote:
>>> Hello everyone,
>>> I am using the EMF project
>>> http://www.eclipse.org/modeling/emft/henshin/.
>>> Currently I am using Henshin to do a model transformation on a UML
>>> model.
>>> The transformed model is contained in an EGraph and saved like this:
>>> options.put(XMIResource.OPTION_SCHEMA_LOCATION,
>>> Boolean.TRUE); Resource resource2 =
>>> resourceSet.createResource(URI.createFileURI("seclinks_corrected.uml"));
>>> resource2.getContents().addAll(graph.getRoots());
>>> try {
>>> resource2.save(options);}
>>> where
>>> org.eclipse.emf.ecore.resource.impl
>>> is used as ResourceImplementation.
>>> What I miss in the saved model are all xmi:id-attributes.
>>> I already had a look at further options in XMIResource but didn't
>>> find an matching options.
>>> I already asked the EMF-people and Ed Merks suggested:
>>> "So you need to be sure to register the necessary UML2 things. They
>>> have some UMLUtil thingy that you can use to initialize a resource
>>> set. Ask questions about UML2 on eclipse.modeling.mdt.uml2"
>>> So here I am :)
>>> Thanks in advance,
>>> Jens
FUDForum. Page generated in 0.04191 seconds
