Home » Eclipse Projects » Eclipse 4 » Progress Bar on Splash Screen(Adding progress bar and message not working (e4))
Progress Bar on Splash Screen [message #955733] Wed, 24 October 2012 01:41 Go to next message
AppleJus Mising name is currently offline AppleJus Mising nameFriend
Member
Adding a progress bar and message to the splash screen from within the product definition used to work in old RCP, but with e4 and all the versions of Eclipse 4.x
it does not seem to be working.
I am now using Version: 4.2.0 Build id: I20120608-1400, and I wonder if any fixes or workarounds have been done in this regard.
Thank you for your help!
[Updated on: Wed, 24 October 2012 01:42]
Report message to a moderator
Re: Progress Bar on Splash Screen [message #956080 is a reply to message #955733] Wed, 24 October 2012 08:18 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph KeimelFriend
See here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=382224
and here: http://www.eclipse.org/forums/index.php/m/884574/?srch=splash#msg_884574
Re: Progress Bar on Splash Screen [message #957009 is a reply to message #956080] Thu, 25 October 2012 00:15 Go to previous messageGo to next message
Member
Thank you Christoph. I had actually come across those links in the past, but it is still unclear to me whether the progress bar is implemented, and less than clear how to integrate the prototype proposed. Could you please shed some light on this?
Re: Progress Bar on Splash Screen [message #957507 is a reply to message #957009] Thu, 25 October 2012 09:20 Go to previous messageGo to next message
The prototype in the bug has a progress bar. Please feel free to try and imrpove it.
The usage is still very close to what I described in this post: http://www.eclipse.org/forums/index.php/mv/msg/328812/857153/#msg_857153
There are some more set* methods in the prototype, to set color, location of the text etc.
Re: Progress Bar on Splash Screen [message #958518 is a reply to message #957507] Fri, 26 October 2012 03:02 Go to previous message
Member
Thank you
Previous Topic:Hook in, after GUI was created and application shell opened.
Next Topic:Lifecycle events on a window
Current Time: Mon May 25 21:55:04 GMT 2020
Powered by FUDForum. Page generated in 0.02013 seconds
