Error while running a test in standard mode [message #134221] |
Mon, 11 August 2008 11:19 |
Originally posted by: robert_kessl.cz.ibm.com
I have been trying to run a test in the standard mode. I'm using
RAD with (based on Eclipse 3.2) with TPTP Automated GUI Recording and
Playback version 4.1.100.
To setup the standard test I'm using the tutorial at:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html
I define the location (I set ECLIPSE_STARTUP_PATH to the location of my
startup.jar file), artifact and pairs.
When I define the test configuration ( run ...) using the created
location/artifact/pair and click run it starts running and stops at 54%.
I do not have any clue what is happening, the .metadata/.log contains only
these (maybe important) errors:
!ENTRY org.eclipse.osgi 2 1 2008-08-11 12:46:26.053
!MESSAGE NLS unused message: AUTO_GUI_ERROR_TST_OBJ_MINE_NFE in:
org.eclipse.tptp.test.auto.gui.internal.messages
!MESSAGE NLS unused message: AUTO_GUI_ERROR_TST_OBJ_MINE_IDG in:
Does anyone have an idea, how to fix this ?
Robert
Re: Error while running a test in standard mode [message #134308 is a reply to message #134298] |
Tue, 12 August 2008 11:13 |
I tried that but it did not help. What I also tried is to
get some more information from Eclipse/TPTP using:
eclipse.exe -debug -consolelog -product com.ibm.rational.rad.product.ide
and modifying the eclipse.ini changing the line containing:
C:\Program Files\IBM\SDP70\jdk\jre\bin\javaw.exe
to
C:\Program Files\IBM\SDP70\jdk\jre\bin\java.exe
After I did this I have got another message on the console:
Exception in thread "Console" java.lang.UnsupportedOperationException
at
org.eclipse.hyades.execution.local.file.FileManagerExtendedI mpl$Adapt
er.determineServerReach(Unknown Source)
at
org.eclipse.hyades.internal.execution.local.common.Console.r un(Unknow
n Source)
I've tried to use TPTP AGR 4.3.0 (the version I'm using right now) and
also AGR 4.2.2. And both versions have the same problem (the exception I
have got is from the 4.3.0).
Robert
FUDForum. Page generated in 0.03149 seconds
