Home » Archived » Visual Editor (VE) » SWT as Library: how to configure source position?
SWT as Library: how to configure source position? [message #134126] Thu, 14 December 2006 05:02 Go to next message
I have (i think) properly installed eclipse 3.2.1 and VE 1.2.1 na di have
created a SWT application referencing SWT as a Library with JFace support.
As usual i have the ability to access the swt/jface source code and javadoc,
but, before a patch to eclipse system via help->software updates (i think
this is the cause of the problem because my problem it's verified for two
times!) now i'm unable to show source and javadocs!
Before post this problem as a bug, i want to try to specify manually the
swt/jface source position of the library, but i don't have found the way to
do this... any suggestion?
Re: SWT as Library: how to configure source position? [message #134163 is a reply to message #134126] Thu, 14 December 2006 12:00 Go to previous messageGo to next message
You can't. It picks it up from the Eclipse SDK that is installed. If you
don't have Eclipse SDK as your target then it can't find the source.
> Thanks :)
Rich Kulp
Re: SWT as Library: how to configure source position? [message #134175 is a reply to message #134163] Fri, 15 December 2006 02:01 Go to previous message
But i have SDK as target!!!...
Maybe it's simply a bug...
Re: SWT as Library: how to configure source position? [message #614859 is a reply to message #134126] Thu, 14 December 2006 12:00 Go to previous message
> Thanks :)
Rich Kulp
Re: SWT as Library: how to configure source position? [message #614860 is a reply to message #134163] Fri, 15 December 2006 02:01 Go to previous message
Previous Topic:Problems to set JME specific classpath while creating LCDUI like GUI editor with VE
Next Topic:VE customize layout problem
Current Time: Sat Jul 19 10:49:57 EDT 2025
Powered by FUDForum. Page generated in 0.04868 seconds
