Home » Newcomers » Newcomers » After "Check for updates" Eclipse fails to load
After "Check for updates" Eclipse fails to load [message #953602] |
Mon, 22 October 2012 11:37 |
Bruce Cartland Messages: 3 Registered: October 2012 |
I'm running Mint 13 KDE 64bit.
I tried the CDT version and the JDT versions. They both startup fine . I run "Check for updates" which does update a bunch of stuff successfully - until the restart and it no longer loads
Any pointers as to what is going wrong?
java -version reports
java version "1.7.0_07" OpenJDK Runtime Environment (IcedTea7 2.3.2) (7u7-2.3.2a-0ubuntu0.12.04.1)
OpenJDK 64-Bit Server VM (build 23.2-b09, mixed mode)
The log, which I cut down, reports:
!SESSION 2012-10-22 21:35:27.575 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.7.0_07
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_AU
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.osgi 2 0 2012-10-22 21:35:32.346
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-10-22 21:35:32.346
!MESSAGE Bundle reference:file:plugins/org.eclipse.recommenders.completion.rcp.calls_1.0.0.v20120914-1432-b175.jar was not resolved.
!SUBENTRY 2 org.eclipse.recommenders.completion.rcp.calls 2 0 2012-10-22 21:35:32.346
!MESSAGE Missing required bundle org.eclipse.recommenders.utils_0.0.0.
!MESSAGE Bundle reference:file:plugins/org.eclipse.wst.dtd.ui_1.0.700.v201203081826.jar was not resolved.
etc,etc,etc..........
!ENTRY org.eclipse.osgi 4 0 2012-10-22 21:35:32.522
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.help.base.infocenterApplication, org.
eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: After "Check for updates" Eclipse fails to load [message #955023 is a reply to message #954839] |
Tue, 23 October 2012 12:41 |
On 10/23/2012 03:41 AM, Bruce Cartland wrote:
> Soooo, openjdk-7-jre-lib was installed. Used synaptic to install
> openjdk-7-jdk and openjdk-7-doc. On a fresh install of Eclipse
> (eclipse-java-juno-linux-gtk-x86_64.tar.gz), I ran "Check for updates".
> This time, after updating most packages, it failed and reported a
> corrupt zip file. Shut down Eclipse, started it up again, then ran
> "Check for updates" again. This time it completed successfully and
> prompted for a restart. The restart worked. Did "Check for updates" and
> this time it reported everything up to date.
> Tried the whole thing again with a fresh install (unzip of the package,
> openjdk installed as above). Got the original error?????
> I speculate therefore that the update process is fragile and can result
> in corrupt downloads which corrupt the installation..... but have no
> idea really. At this stage I've got a working (updated) installation and
> will move on.
I know openjdk is supposed to work, but as long as the real Java from
Sun (Oracle) is still available (and free), I'd never run Eclipse on
anything else. No, I don't know that this has anything to do with your
problem. Just saying, though.
Current Time: Fri Mar 29 09:05:01 GMT 2024
Powered by FUDForum. Page generated in 0.04296 seconds
