probekit question [message #133552] |
Wed, 30 July 2008 01:23 |
Originally posted by: ebraun.site.uottawa.ca
I need to find out when a loop (for, while, etc..) are entered and exited.
Can I find out this information using one of the probekit Fragment types? I
have already got the method entry and exits printing.
eb
Re: probekit question [message #133578 is a reply to message #133565] |
Wed, 30 July 2008 19:07 |
Thanks Paul.
Is there any way of analysing the execution trace created via the probekit
to find loops etc? Using TPTP or anyother free tool.
eb
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:g6ppg4$tge$1@build.eclipse.org...
> Hi eb,
> Method entry and exit is lowest level of granularity available.
> Paul
> "eb" <ebraun@site.uottawa.ca> wrote in message
> news:g6ofrj$51q$1@build.eclipse.org...
>> Hi,
>> exited. Can I find out this information using one of the probekit
>> Fragment types? I have already got the method entry and exits printing.
>> Thanks,
>> eb
Re: probekit question [message #133629 is a reply to message #133591] |
Thu, 31 July 2008 17:54 |
Thanks Paul, you saved me time with your answers.
I managed to generate a trace using the method level (entry/exit probes) I
can get execution trace for all my applications except for an eclipse
plug-in that I am testing. All I am doing is having the entry & exit of
methods printed on the consol and saving the consol to file. I can't see
why it does not work for plug-in, do you?
As for the loop detection a patter matching on the trace might be an easier
way to go since I really don't know the TPTP code.
eb
news:g6semb$6cd$1@build.eclipse.org...
> Hi eb,
> Probekit does not generate a trace. The user-defined probes are weaved
> in the byte code (statically/dynamically) at various support fragment
> types (either callsite or method level). The user-defined probes may
> emit trace data but not Probekit. You would have to modify the TPTP code
> to provide a loop fragment type.
> Paul
> news:g6qe6k$a41$1@build.eclipse.org...
>> Thanks Paul.
>> probekit to find loops etc? Using TPTP or anyother free tool.
>> Thanks,
>> eb
>>> Hi eb,
>>> Paul
>>>> Hi,
>>>> Thanks,
>>>> eb
Re: probekit question [message #133820 is a reply to message #133629] |
Wed, 06 August 2008 10:47 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi eb,
For your Eclipse plug-ins, make sure your probe classes or JAR are on
the plug-in's classpath.
Also, your probe could log the method entry/exit points to a Java
Logging logger, configured to write to a local file.
Paul
news:g6su95$ohu$1@build.eclipse.org...
> of methods printed on the consol and saving the consol to file. I can't
> see why it does not work for plug-in, do you?
> easier way to go since I really don't know the TPTP code.
> eb
>> Hi eb,
>> weaved in the byte code (statically/dynamically) at various support
>> fragment types (either callsite or method level). The user-defined
>> probes may emit trace data but not Probekit. You would have to modify
>> the TPTP code to provide a loop fragment type.
>> Paul
>>> Thanks Paul.
>>> Thanks,
>>> eb
>>>> Hi eb,
>>>> Paul
>>>>> Hi,
>>>>> printing.
>>>>> Thanks,
>>>>> eb
FUDForum. Page generated in 0.02235 seconds
