Home » Modeling » Model-to-Model Transformation » ATL with Xtext Resource(M2M Transformation of Xtext Resource)
ATL with Xtext Resource [message #952382] |
Sun, 21 October 2012 12:06 |
Artem G. Messages: 10 Registered: October 2012 |
Hi Folks,
my brains are burning already -- I work last 2 days with some odd EMFInjector behaviour. I'd like to transform Xtext resource after user input it in DSL editor to another Model. A solution from Guillaume from this thread isn't working any more. So I inject a LazyLinkingResource coming from doGenerate() and get empty file after transformation:
class GenDSLGenerator implements IGenerator {
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
val test = new Transform()
test.transform(resource)
import java.io.File;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.XMIResource;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModel;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.resource.XtextResourceSet;
import org.genetty.DSLStandaloneSetup;
import com.google.inject.Injector;
public class Transform {
* @param args
* @throws Exception
public void transform(Resource res) throws Exception{
ResourceSet resSet = new ResourceSetImpl();
// Create factory and injector
EMFModelFactory factory = new EMFModelFactory();
EMFInjector emfinjector = new EMFInjector();
// Load the DSL metamodel
Resource data =
resSet.getResource(URI.createFileURI("Path to Data.ecore"), true);
Resource DSL =
resSet.getResource(URI.createFileURI("Path to DSL.ecore"), true);
IReferenceModel DSLMetamodel = factory.newReferenceModel();
emfinjector.inject(DSLMetamodel, DSL);
IReferenceModel dataMetamodel = factory.newReferenceModel();
emfinjector.inject(dataMetamodel, data);
// Load the XtextResource as an EMFModel
EMFModel DSLModel = (EMFModel) factory.newModel(DSLMetamodel);
//Inject LazyLinkingResource coming from doGenerate()
emfinjector.inject(DSLModel, res);
IModel dataModel = factory.newModel(dataMetamodel);
ILauncher launcher = (ILauncher) new EMFVMLauncher();
launcher.initialize(null);
launcher.addInModel(DSLModel, "IN", "DSL");
launcher.addOutModel(dataModel, "OUT", "Data");
InputStream asmIS[] = new InputStream[1];
asmIS[0] = new FileInputStream("Path to DSL2Data.asm");
Map<String, Object> launcherOptions = new HashMap<String, Object>();
launcher.launch("run", null, launcherOptions,(Object[]) asmIS);
File file = new File(" path to dataModel.xmi");
FileOutputStream fop = new FileOutputStream(file);
// if file doesnt exists, then create it
if (!file.exists()) {
file.createNewFile();
extractor.extract(dataModel, fop, launcherOptions);
I get this exception:
ERROR org.eclipse.xtext.builder.impl.XtextBuilder - The Xtext resource must contain at least one element.
java.lang.IllegalStateException: The Xtext resource must contain at least one element.
at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:313)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1417)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:986)
at org.eclipse.m2m.atl.core.emf.EMFExtractor.extract(EMFExtractor.java:65)
at org.eclipse.m2m.atl.core.emf.EMFExtractor.extract(EMFExtractor.java:80)
at org.genetty.transformer.Trans.trans(Trans.java:87)
at org.genetty.generator.DSLGenerator.doGenerate(DSLGenerator.java:15)
at org.eclipse.xtext.builder.BuilderParticipant.handleChangedContents(BuilderParticipant.java:259)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:194)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:161)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:141)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:91)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
but in debug I see that this LazyLinkingResource has all EObject I need.
So if I persist this LazyLinkingResource as XMIResource and load it as InputStream all this stuff working. This is very-very strange.
* @param args
* @throws Exception
Resource data =
Resource DSL =
//Persist LazyLinkingResource coming from doGenerate()
XMIResourceFactoryImpl resFactory = new XMIResourceFactoryImpl();
URI xmiuri = URI.createFileURI("path to outputGenDSL.xmi");
XMIResource xmiresource = (XMIResource) resFactory.createResource(xmiuri);
EObject xtextModel = res.getAllContents().next();
xmiresource.getContents().add(xtextModel);
xmiresource.save(new HashMap());
//Load persisted resource as InputStream
InputStream is[] = new InputStream[1];
is[0] = new FileInputStream("path to outputGenDSL.xmi");
Map<String, Object> options = new HashMap<String, Object>();
//Inject loaded stuff
emfinjector.inject(DSLModel,is[0], options);
If I use Guillaumes solution I get empty file at the end:
* @param args
* @throws Exception
Resource data =
Resource DSL =
DSLStandaloneSetup dsl = new DSLStandaloneSetup();
Injector injector = dsl.createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
Resource resource = resourceSet.getResource(URI.createURI("platform:/resource/genTest/test.dsl"), true);
emfinjector.inject(DSLModel, resource);
Any help would be very appreciated! Thanks, Artem.
Re: ATL with Xtext Resource [message #952596 is a reply to message #952382] |
Sun, 21 October 2012 16:03 |
Ed Willink Messages: 7655 Registered: July 2009 |
You're more likely to get a sensible answer on the ATL newsgroup.
You don't seem to call DSLStandaloneSetup.doSetup().
Ed Willink
On 21/10/2012 13:07, Artem G. wrote:
> Hi Folks,
> from
> http://www.eclipse.org/forums/index.php/mv/msg/159523/506695/#msg_506695
> * @param args
> * @throws Exception */
> Resource data =
> Resource DSL =
> Object>();
> least one element.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> * @param args
> Resource data =
> Resource DSL =
> Object>();
> * @param args
> Resource data =
> Resource DSL =
> DSLStandaloneSetup(); Injector injector =
> Boolean.TRUE);
> Resource resource =
> true);
> Object>();
Re: ATL with Xtext Resource [message #952613 is a reply to message #952596] |
Sun, 21 October 2012 16:23 |
Hi Ed, thanks for reply!
Adding DSLStandaloneSetup.doSetup(); brings nothing, while:
public class DSLStandaloneSetup extends DSLStandaloneSetupGenerated{
public static void doSetup() {
new DSLStandaloneSetup().createInjectorAndDoEMFRegistration();
this is the same, what I'm doing at the begin.
Should I cross-post this treat to the ATL newsgroup?
-a
[Updated on: Sun, 21 October 2012 16:23] Report message to a moderator
Current Time: Fri Mar 29 00:46:10 GMT 2024
Powered by FUDForum. Page generated in 0.03484 seconds
