Home » Eclipse Projects » Remote Application Platform (RAP) » Doubt creating a custom widget
Doubt creating a custom widget [message #132937] |
Fri, 15 May 2009 05:52  |
Kathiravan  Messages: 33 Registered: July 2009 |
Member |
I am trying to create a custom widget to add a <svg> dom node. I have
looked into the custom widget example.
As a starting point, i created the widget with just a label to get the
custom widget working,
qx.Class.define( "com.biologistics.gd.designview.DesignWidget", {
extend: qx.ui.core.Widget,
construct: function( id ) {
this.setHtmlAttribute("id",id);
this._id = id;
properties : {
partId : {
init : "",
apply : "load"
members : {
load : function() {
var current = this.getPartId();
if( current != null && current != "" ) {
qx.ui.core.Widget.flushGlobalQueues();
var id = document.getElementById( this._id );
var label1 = new qx.ui.basic.Label(current);
add(label1);
I create an instance of the widget inside a viewpart->createPartControl
method.
But when i open the view, i get the following error, this may be a very
basic doubt :-) , ( but i googled enough for this )
Could not evaluate javascript response:
TypeError: this._layoutChanges is undefined
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "22" );var wm
= org.eclipse.swt.WidgetManager.getInstance();var w = wm.findWidgetById(
"w192" );w.doClose();wm.dispose( "w192" );wm.dispose( "w205" );wm.dispose(
"w230" );wm.dispose( "w191" );wm.dispose( "w190" );wm.dispose( "w206"
);wm.dispose( "w207" );wm.dispose( "w211" );wm.dispose( "w188" );var w =
wm.findWidgetById( "w222" );w.destroy();wm.dispose( "w222" );var w =
wm.findWidgetById( "w229" );w.destroy();wm.dispose( "w229" );var w =
wm.findWidgetById( "w228" );w.destroy();wm.dispose( "w228" );var w =
wm.findWidgetById( "w227" );w.destroy();wm.dispose( "w227" );var w =
wm.findWidgetById( "w226" );w.destroy();wm.dispose( "w226" );var w =
wm.findWidgetById( "w225" );w.destroy();wm.dispose( "w225" );var w =
wm.findWidgetById( "w224" );w.destroy();wm.dispose( "w224" );var w =
wm.findWidgetById( "w223" );w.destroy();wm.dispose( "w223" );var w =
wm.findWidgetById( "w220" );w.destroy();wm.dispose( "w220" );var w =
wm.findWidgetById( "w221" );w.destroy();wm.dispose( "w221" );var w =
wm.findWidgetById( "w218" );w.destroy();wm.dispose( "w218" );var w =
wm.findWidgetById( "w219" );w.destroy();wm.dispose( "w219" );var w =
wm.findWidgetById( "w216" );w.destroy();wm.dispose( "w216" );var w =
wm.findWidgetById( "w217" );w.destroy();wm.dispose( "w217" );var w =
wm.findWidgetById( "w214" );w.destroy();wm.dispose( "w214" );var w =
wm.findWidgetById( "w215" );w.destroy();wm.dispose( "w215" );var w =
wm.findWidgetById( "w212" );w.destroy();wm.dispose( "w212" );var w =
wm.findWidgetById( "w213" );w.destroy();wm.dispose( "w213" );wm.dispose(
"w208" );wm.dispose( "w209" );wm.dispose( "w210" );wm.dispose( "w187"
);var w = wm.findWidgetById( "w25" );w.setActive( true );var w =
wm.findWidgetById( "w45" );w.setWidth( 26 );w.setHeight( 22 );var w =
wm.newWidget( "w231", "w69", true, null, 'qx.ui.toolbar.ToolBar'
);w.addState( "rwt_FLAT" );w.setSpace( 0, 0, 0, 0 );w.setZIndex( 300
);w.setVisibility( false );var w = wm.newWidget( "w232", "w69", true,
null, 'qx.ui.layout.CanvasLayout' );w.setOverflow( "hidden"
);w.setHideFocus( true );w.setAppearance( "composite" );w.setSpace( 175,
956, 562, 149 );w.setZIndex( 299 );var t = wm.findWidgetById( "w25"
);t.addActivateListenerWidget( w );var w = wm.newWidget( "w233", "w232",
true, null, 'qx.ui.layout.CanvasLayout' );w.setOverflow( "hidden"
);w.setHideFocus( true );w.setAppearance( "composite" );w.setSpace( 0,
956, 0, 149 );w.setZIndex( 300 );var w = wm.newWidget( "w234", "w233",
true, null, 'com.biologistics.gd.designview.DesignWidget', '"w234"'
);w.setAppearance( "composite" );w.setOverflow( "hidden" );w.setSpace( 0,
956, 0, 149 );w.setZIndex( 300 );w.setTabIndex( 31 );w.setPartId( "New
Part" );var w = wm.findWidgetById( "w193" );w.setZIndex( 298 );var w =
wm.findWidgetById( "w194" );w.setZIndex( 297 );var w = wm.findWidgetById(
"w70" );w.setZIndex( 296 );var w = wm.findWidgetById( "w74" );w.setZIndex(
295 );var w = wm.findWidgetById( "w80" );w.setZIndex( 294 );var w =
wm.findWidgetById( "w81" );w.setZIndex( 293 );w.setVisibility( false );var
w = wm.findWidgetById( "w83" );w.setZIndex( 292 );var w =
wm.findWidgetById( "w88" );w.setZIndex( 291 );var w = wm.findWidgetById(
"w91" );w.setZIndex( 290 );var w = wm.findWidgetById( "w92" );w.setZIndex(
289 );var w = wm.findWidgetById( "w105" );w.setZIndex( 288 );var w =
wm.findWidgetById( "w117" );w.setZIndex( 287 );w.setTabIndex( -1
);w.setSelectionForeground( "#705e42" );w.setSelectionBackground(
"#ffffff" );var w = wm.findWidgetById( "w131" );w.setZIndex( 286 );var w =
wm.findWidgetById( "w143" );w.setZIndex( 285 );w.setTabIndex( 20
);w.setSelectionForeground( "#ffffff" );w.setSelectionBackground(
"#56a0ea" );var w = wm.findWidgetById( "w144" );w.setSpace( 0, 83, 0, 24
);w.setSelected( false );var w = wm.newWidget( "w235", "", false, null,
'org.eclipse.swt.custom.CTabItem', 'wm.findWidgetById( "w143" ), true'
);var t = wm.findWidgetById( "w143" );t.add( w );w.setSpace( 83, 170, 0,
24 );w.setLabel( "Custom Design View" );w.setIcon(
"25.fwk19731881/icons/full/eview16/defaultview_misc.gif"
);w.setUnselectedCloseVisible( false );w.setSelected( true );var w =
wm.findWidgetById( "w148" );w.setSpace( 253, 669, 1, 22 );var w =
wm.findWidgetById( "w149" );w.setTabIndex( 23 );var w = wm.findWidgetById(
"w155" );w.setZIndex( 284 );var w = wm.findWidgetById( "w167"
);w.setZIndex( 283 );var w = wm.findWidgetById( "w168" );w.setZIndex( 282
);var w = wm.findWidgetById( "w169" );w.setZIndex( 281 );var w =
wm.findWidgetById( "w25" );w.setActiveControl( wm.findWidgetById( "w40" )
);org.eclipse.swt.WidgetManager.getInstance().focus( "w40"
);qx.ui.core.Widget.flushGlobalQueues();org.eclipse.swt.Even tUtil.resumeEventHandling();org.eclipse.swt.FontSizeCalculat ion.measureStrings(
[ [ 8174886, "C", [ "Segoe UI", "Corbel", "Calibri", "Tahoma", "Lucida
Sans Unicode", "sans-serif" ], 11, false, false, -1 ], [ 4852582, "Custom
Design View", [ "Segoe UI", "Corbel", "Calibri", "Tahoma", "Lucida Sans
Unicode", "sans-serif" ], 11, false, false, -1 ] ] );
And also what would be best way to add the svg dom node to the widget. Any
suggestions?
Kathir.
Re: Doubt creating a custom widget [message #132967 is a reply to message #132937] |
Fri, 15 May 2009 07:12   |
Ivan Furnadjiev Messages: 2396 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Kathiravan,
I suppose that the Javascript error is because of the class that your
custom widget extends - qx.ui.core.Widget. If you look at the GMap
custom widget example, it extends qx.ui.layout.CanvasLayout.
About your second question - you can use:
var svg = document.createElement( "svg" );
---<set svg element attributes and styles here>---
this.add( svg );
Best,
Ivan
Kathiravan wrote:
> Hi
> this._id = id;
> properties : {
> partId : {
> init : "",
> apply : "load"
> members : {
> load : function() {
> add(label1);
> viewpart->createPartControl method.
> very basic doubt :-) , ( but i googled enough for this )
> );var wm = org.eclipse.swt.WidgetManager.getInstance();var w =
> wm.findWidgetById( "w192" );w.doClose();wm.dispose( "w192"
> );wm.dispose( "w205" );wm.dispose( "w230" );wm.dispose( "w191"
> );wm.dispose( "w190" );wm.dispose( "w206" );wm.dispose( "w207"
> );wm.dispose( "w211" );wm.dispose( "w188" );var w = wm.findWidgetById(
> "w222" );w.destroy();wm.dispose( "w222" );var w = wm.findWidgetById(
> "w229" );w.destroy();wm.dispose( "w229" );var w = wm.findWidgetById(
> "w228" );w.destroy();wm.dispose( "w228" );var w = wm.findWidgetById(
> "w227" );w.destroy();wm.dispose( "w227" );var w = wm.findWidgetById(
> "w226" );w.destroy();wm.dispose( "w226" );var w = wm.findWidgetById(
> "w225" );w.destroy();wm.dispose( "w225" );var w = wm.findWidgetById(
> "w224" );w.destroy();wm.dispose( "w224" );var w = wm.findWidgetById(
> "w223" );w.destroy();wm.dispose( "w223" );var w = wm.findWidgetById(
> "w220" );w.destroy();wm.dispose( "w220" );var w = wm.findWidgetById(
> "w221" );w.destroy();wm.dispose( "w221" );var w = wm.findWidgetById(
> "w218" );w.destroy();wm.dispose( "w218" );var w = wm.findWidgetById(
> "w219" );w.destroy();wm.dispose( "w219" );var w = wm.findWidgetById(
> "w216" );w.destroy();wm.dispose( "w216" );var w = wm.findWidgetById(
> "w217" );w.destroy();wm.dispose( "w217" );var w = wm.findWidgetById(
> "w214" );w.destroy();wm.dispose( "w214" );var w = wm.findWidgetById(
> "w215" );w.destroy();wm.dispose( "w215" );var w = wm.findWidgetById(
> "w212" );w.destroy();wm.dispose( "w212" );var w = wm.findWidgetById(
> "w213" );w.destroy();wm.dispose( "w213" );wm.dispose( "w208"
> );wm.dispose( "w209" );wm.dispose( "w210" );wm.dispose( "w187" );var w
> 175, 956, 562, 149 );w.setZIndex( 299 );var t = wm.findWidgetById(
> "w25" );t.addActivateListenerWidget( w );var w = wm.newWidget( "w233",
> "w232", true, null, 'qx.ui.layout.CanvasLayout' );w.setOverflow(
> "hidden" );w.setHideFocus( true );w.setAppearance( "composite"
> );w.setSpace( 0, 956, 0, 149 );w.setZIndex( 300 );var w =
> wm.newWidget( "w234", "w233", true, null,
> 0, 956, 0, 149 );w.setZIndex( 300 );w.setTabIndex( 31 );w.setPartId(
> "New Part" );var w = wm.findWidgetById( "w193" );w.setZIndex( 298
> );var w = wm.findWidgetById( "w194" );w.setZIndex( 297 );var w =
> wm.findWidgetById( "w70" );w.setZIndex( 296 );var w =
> wm.findWidgetById( "w74" );w.setZIndex( 295 );var w =
> );var w = wm.findWidgetById( "w83" );w.setZIndex( 292 );var w =
> wm.findWidgetById( "w91" );w.setZIndex( 290 );var w =
> wm.findWidgetById( "w92" );w.setZIndex( 289 );var w =
> w = wm.findWidgetById( "w143" );w.setZIndex( 285 );w.setTabIndex( 20
> 24 );w.setSelected( false );var w = wm.newWidget( "w235", "", false,
> null, 'org.eclipse.swt.custom.CTabItem', 'wm.findWidgetById( "w143" ),
> true' );var t = wm.findWidgetById( "w143" );t.add( w );w.setSpace( 83,
> 170, 0, 24 );w.setLabel( "Custom Design View" );w.setIcon(
> wm.findWidgetById( "w155" );w.setZIndex( 284 );var w =
> wm.findWidgetById( "w167" );w.setZIndex( 283 );var w =
> wm.findWidgetById( "w168" );w.setZIndex( 282 );var w =
> "w40" ) );org.eclipse.swt.WidgetManager.getInstance().focus( "w40"
> "Custom Design View", [ "Segoe UI", "Corbel", "Calibri", "Tahoma",
> "Lucida Sans Unicode", "sans-serif" ], 11, false, false, -1 ] ] );
> Any suggestions?
> Kathir.
Re: Doubt creating a custom widget [message #133149 is a reply to message #132967] |
Sat, 16 May 2009 07:21   |
Member |
Hi Ivan,
For the svg node, i have added the following,
var svg = document.createElement("svg");
var svgChild1 = document.createElement("rect");
svgChild1.setAttribute("x","10");
svgChild1.setAttribute("y","20");
svgChild1.setAttribute("width","100");
svgChild1.setAttribute("height","50");
svgChild1.setAttribute("fill","red");
svg.appendChild(svgChild1);
svg.setAttribute("xmlns","http://www.w3.org/2000/svg");
svg.setAttribute("width","400");
svg.setAttribute("height","450");
this.add(svg);
But when i run this i get the following error,
Error: Invalid Widget: [object HTMLUnknownElement]
and instead of adding the svg node to the widget, if i directly add to the
document body, it adds up the svg node to the end of the dom but this is
not what i want.
Are there any tutorials on learning qooxdoo for this kind of requirement.
BR,
Kathir.
Re: Doubt creating a custom widget [message #133162 is a reply to message #133149] |
Sat, 16 May 2009 08:19   |
Hi Kathiravan,
the qooxdoo 0.7 documentation is available at [1].
[1] http://qooxdoo.org/documentation/0.7
Best,
Ivan
Kathiravan wrote:
> Hi Ivan,
> this.add(svg);
> the document body, it adds up the svg node to the end of the dom but
> this is not what i want.
> BR,
> Kathir.
Current Time: Tue Jan 31 17:41:24 GMT 2023
Powered by FUDForum. Page generated in 0.07650 seconds
