Home » Eclipse Projects » Remote Application Platform (RAP) » Group + Scrollbar
Group + Scrollbar [message #132227] |
Mon, 11 May 2009 13:28 |
No real name Messages: 38 Registered: July 2009 |
Member |
I have problems with scrollbars in a group. I have a dialog window with a
group. In this group are some controls. If I push a button, the group gets
a new line with the same controls. It works well until the size of my
dialog window is to small for the number of lines in the group. How can I
get a scrollbar?
I have the following code.
protected Control createDialogArea(Composite parent) {
Composite topComposite = (Composite)
super.createDialogArea(parent);
GridLayout layout = new GridLayout(3, false);
layout.marginLeft = 5;
layout.marginTop = 10;
layout.horizontalSpacing = 5;
layout.makeColumnsEqualWidth = false;
topComposite.setLayout(layout);
GridData gd = new GridData();
Button andButton = new Button(topComposite, SWT.RADIO);
andButton.setText("It all conditions must be fulfilled");
Button orButton = new Button(topComposite, SWT.RADIO);
orButton.setText("There must be at least one of the conditions are
met.");
orButton.setSelection(true);
Composite right = new Composite(topComposite, SWT.NONE);
layout = new GridLayout();
layout.numColumns = 1;
layout.marginWidth = 10;
right.setLayout(layout);
gd.horizontalSpan = 1;
gd.horizontalAlignment = GridData.HORIZONTAL_ALIGN_END;
btnAdd = new Button(right, SWT.NONE);
btnAdd.setText("+");
btnAdd.addMouseListener(new MouseListener() {
public void mouseUp(MouseEvent arg0) {
addValueDisplayNameGuiElement("");
public void mouseDoubleClick(MouseEvent arg0) {
public void mouseDown(MouseEvent arg0) {
gd.horizontalSpan = 3;
gd.horizontalAlignment = GridData.FILL;
gd.verticalAlignment = GridData.FILL;
gd.grabExcessHorizontalSpace = true;
gd.grabExcessVerticalSpace = true;
Group grpValues = new Group(topComposite, SWT.H_SCROLL);
grpValues.setText("Values");
grpValues.setLayoutData(gd);
GridLayout grpLayout = new GridLayout(1, false);
grpValues.setLayout(grpLayout);
pnlValues = new Composite(grpValues, SWT.H_SCROLL);
GridLayout pnlValuesLayout = new GridLayout(4, false);
pnlValuesLayout.marginTop = 5;
pnlValues.setLayout(pnlValuesLayout);
pnlValues.setLayoutData(gd);
applyDialogFont(topComposite);
return topComposite;
protected void addValueDisplayNameGuiElement(String text) {
Combo combo = new Combo(this.pnlValues, SWT.READ_ONLY);
combo.setItems(ITEMS);
combo.select(0);
Combo whereCombo = new Combo(this.pnlValues, SWT.READ_ONLY);
String[] whereItems = new String[] {"contains", "doesn't contain"};
whereCombo.setItems(whereItems);
whereCombo.select(0);
Text textNew = new Text(this.pnlValues, SWT.NONE);
textNew.setLayoutData(new GridData(230, 20));
textNew.setEditable(true);
Button minusButton = new Button(this.pnlValues, SWT.PUSH);
minusButton.setText("-");
minusButton.setLayoutData(new GridData(20,20));
minusButton.addMouseListener(new RemoveValueListener(combo,
whereCombo,textNew,minusButton));
this.pnlValues.layout();
allValueFields.add(combo);
kristin
Re: Group + Scrollbar [message #132265 is a reply to message #132227] |
Mon, 11 May 2009 15:15 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Kristin,
you probably need a ScrolledComposite. The ScrolledComposite is a
complicated thing and it's easily screwed up. Thus, besides the
JavaDoc, you should also have a look at the SWT snippets [1] for
examples.
HTH
Rüdiger
[1] http://www.eclipse.org/swt/snippets/
Kristin Polenz wrote:
> Hello,
> a group. In this group are some controls. If I push a button, the group
> gets a new line with the same controls. It works well until the size of
> my dialog window is to small for the number of lines in the group. How
> can I get a scrollbar? I have the following code.
> Composite topComposite = (Composite) super.createDialogArea(parent);
> are met.");
> combo.select(0);
> RemoveValueListener(combo, whereCombo,textNew,minusButton));
> kristin
Current Time: Wed Apr 24 20:34:12 GMT 2024
Powered by FUDForum. Page generated in 0.02640 seconds
