Re: Update View Dynamically? [message #948940 is a reply to message #948826] |
Thu, 18 October 2012 14:34 |
Peter,
What you are looking for is the UICallback. See the FAQ entry here[1]. Keep in mind that the UICallback must be activated from the display thread. Also remember that you can/will have multiple clients connected, each with their own display and their own databinding realm. I think you would need each viewer to have its own IObservableList and only update that list from its display thread using asyncExec(). If there is a shared data model, then you would need to have each client register a listener which holds a reference to its Display that it can use to call asyncExec() which notified of a change to the model. Then, of course, be sure to cleanup all of the listeners when the display/viewer is disposed.
[1] http://wiki.eclipse.org/RAP/FAQ#How_to_update_the_UI_from_a_background_thread
Hope that helps,
Cole
FUDForum. Page generated in 0.02799 seconds
