Bundle cannot be retrieved [message #948074] |
Wed, 17 October 2012 18:30 |
Bastian Roth Messages: 19 Registered: September 2009 |
Junior Member |
Hello everybody,
during startup, I get some strange error messages after I've moved a few classes from my e4 RCP application to another (newly created) plugin:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-17 20:14:35.333
!MESSAGE Unable to retrieve the bundle from the URI: bundleclass://org.eclipse.e4.ui.workbench.renderers.swt/org.eclipse.e4.ui.workbench.renderers.swt.WorkbenchRendererFactory
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-17 20:14:35.334
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-17 20:14:35.336
!MESSAGE Unable to create class 'org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine' from bundle '45'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalStateException: Could not create any rendering factory. Aborting ...
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.instantiateRenderer(E4Workbench.java:100)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:83)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.IllegalStateException: Could not create any rendering factory. Aborting ...
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.initialize(PartRenderingEngine.java:434)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 24 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-17 20:14:35.341
!MESSAGE Failed to create the presentation engine for URI: bundleclass://org.eclipse.e4.ui.workbench.swt/org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine
Of course, in the dependencies list of the corresponding product I have put a reference to org.eclipse.e4.ui.workbench.renderers.swt. So, are there any ideas or hints why this error occurs and how it can be eliminated?
Thanks in advance,
Bastian
[Updated on: Thu, 18 October 2012 07:23] Report message to a moderator
Re: Bundle cannot be retrieved [message #1062483 is a reply to message #948074] |
Sat, 08 June 2013 01:49 |
Edward MacKerrow Messages: 7 Registered: July 2010 Location: Santa Fe, New Mexico |
Junior Member |
I had the same error ( I was working on the Vogella e4 RCP tutorial
Then I was able to get things to work by:
(1) adding org.eclipse.e4.ui.workbench.renderers.swt to my dependencies
(2) deselecting all under my runtime configuration, then selecting the my RCP app, and add required plugins (with the check for optional dependencies selected).
Here is my Manifest.MF file:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Wizard
Bundle-SymbolicName: com.example.e4.rcp.wizard; singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Vendor: EXAMPLE
Require-Bundle: javax.inject;bundle-version="1.0.0",
org.eclipse.core.runtime;bundle-version="3.8.0",
org.eclipse.swt;bundle-version="3.100.1",
org.eclipse.jface;bundle-version="3.8.102",
org.eclipse.e4.ui.services;bundle-version="0.10.3",
org.eclipse.e4.ui.workbench;bundle-version="0.11.0",
org.eclipse.e4.core.di;bundle-version="1.2.0",
org.eclipse.e4.ui.di;bundle-version="0.10.1",
org.eclipse.e4.core.contexts;bundle-version="1.2.0",
org.eclipse.e4.ui.workbench.renderers.swt;bundle-version="0.10.3"
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
Import-Package: javax.annotation;version="1.0.0"
Here is my plugin.xml file
<plugin>
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product
name="com.example.e4.rcp.wizard"
application="org.eclipse.e4.ui.workbench.swt.E4Application">
<property
name="clearPersistedState"
value="true">
</property>
<property
name="applicationCSS"
value="platform:/plugin/com.example.e4.rcp.wizard/css/default.css">
</property>
<property
name="appName"
value="com.example.e4.rcp.wizard">
</property>
</product>
</extension>
</plugin>
Things worked fine after the above steps.
FUDForum. Page generated in 0.02534 seconds
