Home » Eclipse Projects » DSDP - Target Management » Attempt to open SSH shell produces "invalid server's version string"
Attempt to open SSH shell produces "invalid server's version string" [message #12041] |
Thu, 05 July 2007 22:42 |
Thomas D. Johnson Messages: 72 Registered: July 2009 |
Member |
Using RSE 2.0 with Eclipse 3.3.0 on Windows, when I attempt to open a
shell on one machine with SSH, it succeeds, but with another machine,
the attempt fails, and generates the following error log/traceback:
com.jcraft.jsch.JSchException: invalid server's version string
at com.jcraft.jsch.Session.connect(Session.java:253)
at
org.eclipse.rse.internal.connectorservice.ssh.SshConnectorSe rvice.internalConnect(SshConnectorService.java:121)
at
org.eclipse.rse.core.subsystems.AbstractConnectorService.con nect(AbstractConnectorService.java:412)
at
org.eclipse.rse.internal.shells.ui.actions.SystemCommandActi on.connect(SystemCommandAction.java:611)
at
org.eclipse.rse.internal.shells.ui.actions.SystemCommandActi on.access$0(SystemCommandAction.java:604)
at
org.eclipse.rse.internal.shells.ui.actions.SystemCommandActi on$RunShellJob.run(SystemCommandAction.java:113)
What puzzles me is that on the (server) machine where I succeed, I see:
v > ssh -V
OpenSSH_3.8p1, SSH protocols 1.5/2.0, OpenSSL 0.9.7g 11 Apr 2005
but on the (server) machine where I fail, I see:
j > ssh -V
Are there some additional traces that I can enable so I can actually see
the "invalid server's version string"?
By the way, I can use SSH (on the native command line) to reach "j" from
"v", and I can reach both "j" and "v" using PuTTY from the Windows
machine that I'm using to run Eclipse 3.3.0 and RSE 2.0
Thanks in advance for any hints,
Tom Johnson
Re: Attempt to open SSH shell produces "invalid server's version string" [message #12055 is a reply to message #12041] |
Mon, 09 July 2007 14:23 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hi Tom,
by running ssh -V you just check the ssh client version on your
machines. But what we'd like to know is the sshd server version. You can
check this by logging in to the remote hosts with verbose logging enabled:
482 mober@parser~>ssh -v osgiliath
OpenSSH_3.9p1, OpenSSL 0.9.7a Feb 19 2003
debug1: Remote protocol version 1.99, remote software version OpenSSH_4.4
debug1: match: OpenSSH_4.4 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_3.9p1
As you see, on my local machine I have OpenSSH_3.9p1 but on the remote
machine I have OpenSSH_4.4. Try this on you two machines and look at the
differences. Another option to try on your servers is
ps -ef | grep sshd
and you'll see where the sshd is actually running from. If still unclear
after these checks, you may want to contact the Jsch-users mailing list
at https://lists.sourceforge.net/lists/listinfo/jsch-users
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> v > ssh -V
> j > ssh -V
> Tom Johnson
Re: Attempt to open SSH shell produces "invalid server's version string" [message #568667 is a reply to message #12041] |
Hi Tom,
ps -ef | grep sshd
Martin Oberhuber
> at
> at
> at
> at
> at
> v > ssh -V
> j > ssh -V
> Tom Johnson
Current Time: Fri Apr 19 04:55:52 GMT 2024
Powered by FUDForum. Page generated in 0.02039 seconds
