Transient 'Missing Constraint' problem [message #131264] |
Thu, 14 May 2009 16:19 |
michael.sacarny Messages: 103 Registered: July 2009 Location: USA |
In an RCP Product based on SDK 3.5M7, we get a one-time "Missing
Constraint" Error Log entry at start up indicating o.e.equinox.ds is
missing
o.e.equinox.internal.util.event (see below). Both of these plugins,
however, are in the Plugins folder.
- If I start with -console and run diag on o.e.equinox.ds and
o.e.equinox.util, they both report "No unresolved constraints".
- The problem did not exist in SDK 3.4.1.
- The error only occurs on the very first start up or when run with -clean
option.
- I ran with -debug option and the .options file from org.eclipse.osgi and
found the debug entries of the initial failure and eventual resolution:
*** BEGIN RESOLUTION ***
** RESOLVING
[org.eclipse.equinox.simpleconfigurator_1.0.100.v20090429-21 26] **
[org.eclipse.equinox.simpleconfigurator_1.0.100.v20090429-21 26] RESOLVED
** RESOLVING [org.eclipse.equinox.transforms.hook_1.0.100.v200905131629] **
** RESOLVING [org.eclipse.equinox.ds_1.1.0.v20090429-1630] **
** IMPORT
org.eclipse.equinox.internal.util.event[org.eclipse.equinox. ds_1.1.0.v20090429-1630]
failed to resolve
[org.eclipse.equinox.ds_1.1.0.v20090429-1630] NOT RESOLVED
*** END RESOLUTION ***
** IMPORT
failed to resolve
Time to load bundles: 47
** IMPORT
failed to resolve
** RESOLVING
[org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20090429-2 045] **
[org.eclipse.equinox.util_1.0.100.v20090429-1630] RESOLVED
[org.eclipse.equinox.ds_1.1.0.v20090429-1630] RESOLVED
** RESOLVING [org.eclipse.ui.views_3.4.0.I20090421-0800] **
- [org.eclipse.ui.views_3.4.0.I20090421-0800] already resolved
So, it looks like the initial failures to resolve are transient. Does
anyone know what this could be or how better to diagnose it? I've run out
of ideas.
MSacarny
Original error log entry:
!ENTRY org.eclipse.equinox.ds 4 0 2009-05-13 17:35:10.998
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package:
org.eclipse.equinox.internal.util.event; version="1.0.0" at
org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1313)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1297)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:309)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:220)
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:330)
FUDForum. Page generated in 0.02793 seconds
