verticalIndent missing for GridData (SWT) [message #131115] |
Wed, 20 September 2006 13:29  |
Hallo all,
is there a special reason, why the verticalIndent is not in the list of
GridData properties? Is there a better way to get some vertical
space between widgets?
Thx,
Michael
Re: verticalIndent missing for GridData (SWT) [message #131391 is a reply to message #131324] |
Fri, 22 September 2006 10:50   |
That's correct. The current selection is the property sheet, not the VE.
So it has different set of selections (the selected object is a property
sheet entry, the layout dialog doesn't know what to display for that).
If you select the VE again the custom layout is restored.
Michael Maluck wrote:
> Ah, I see. It would be great to have this option in the customize layout
> window, too.
> Btw if I select a component I can see several options in the customize
> layout window. If I click on any property in the properties view now all
> options in the customize layout window disapper.
> On Thu, 21 Sep 2006 10:25:52 -0400, Rich Kulp wrote:
>>Basically we didn't know the field had been added. So we didn't put
>>support in for it.
>>michael wrote:
>>>Hallo all,
>>>GridData properties? Is there a better way to get some vertical space
>>>between widgets?
>>>Thx,
>>>Michael
Re: verticalIndent missing for GridData (SWT) [message #131402 is a reply to message #131391] |
Mon, 25 September 2006 02:44  |
This is the technical way of seeing things. Seeing it as a user, I think
it's annoying. :)
>> window, too.
>>> support in for it.
>>> michael wrote:
>>>> Hallo all,
>>>> between widgets?
>>>> Thx,
>>>> Michael
Re: verticalIndent missing for GridData (SWT) [message #614644 is a reply to message #131115] |
Thu, 21 September 2006 10:25  |
support in for it.
michael wrote:
> Hallo all,
> Thx,
> Michael
Re: verticalIndent missing for GridData (SWT) [message #614649 is a reply to message #131262] |
Fri, 22 September 2006 03:22  |
window, too.
> support in for it.
> michael wrote:
>> Hallo all,
>> between widgets?
>> Thx,
>> Michael
Re: verticalIndent missing for GridData (SWT) [message #614655 is a reply to message #131324] |
> window, too.
>>support in for it.
>>michael wrote:
>>>Hallo all,
>>>between widgets?
>>>Thx,
>>>Michael
Re: verticalIndent missing for GridData (SWT) [message #614656 is a reply to message #131391] |
it's annoying. :)
>> window, too.
>>> support in for it.
>>> michael wrote:
>>>> Hallo all,
>>>> between widgets?
>>>> Thx,
>>>> Michael
FUDForum. Page generated in 0.26872 seconds
