IWAT0284EThe agent controller is not available on host localhost. [message #130943] |
Fri, 06 June 2008 16:44 |
Originally posted by: sdhjosh.yahoo.com
I am trying to get to know about Spring framework and also I am new to
junit.
So I am following the spring tutorial where it talks about a junit test.
So I create a TPTP junit test in eclipse and eclipse also creates a test
suite for me which is great.
However when I try to run the test suite or the test.java file (Right
Click => Run as => Test) I get the following error.
Connection failed on host localhost.
Reason:
Make sure that:
*the agent controller is installed
*the agent controller is configured to communicate with your machine.
*you have the correct host name and port number for the agent controller.
When I click on "details" I get
" org.elipse.hyades.internal.execution.local.control.AgentCont rollerUnavailableException "
I have been following some threads in eclipse.tptp newslist, they all talk
about different issues but with the same error.
Can anyone help me out here?
Thnx.
Re: IWAT0284EThe agent controller is not available on host localhost. [message #131019 is a reply to message #130995] |
Mon, 09 June 2008 15:01 |
Hi Paul,
I have Integrated Agent Controller enabled under windows => Preferences =>
AgentController => Integrated Agent Controller.
I have the port as 10002 under windows => Preferences => Test and Default
host name as Localhost.
I also downloaded and installed the Agent Controller and configured it as
per the instructions and still the same error.
Also under profiling and Logging I have the agent controller port as 10002.
I am not sure if the profiling and Logging setting has anything to do with
the junit test I am trying to run.
I get the same error even when I run the "Test Connection" under windows
=> Preferences => Profiling and Logging => Hosts.
FUDForum. Page generated in 0.03909 seconds
