Home » Modeling » TMF (Xtext) » first and last character truncated in STRING terminals
first and last character truncated in STRING terminals [message #943160] Sun, 14 October 2012 07:51 Go to next message
Andrea Sindico is currently offline Andrea SindicoFriend
I have redefined the STRING terminal this way
terminal STRING : ('.'|'+'|'('|')'|'a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
because I have to recognize STRING not delimited by " or '
the problem is that, though the generated parser works, it truncates the first and the last character of the recognized string. What am I missing?
Re: first and last character truncated in STRING terminals [message #943165 is a reply to message #943160] Sun, 14 October 2012 07:58 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi you have to change the valueconverter too
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: first and last character truncated in STRING terminals [message #943172 is a reply to message #943165] Sun, 14 October 2012 08:07 Go to previous messageGo to next message
Hi Christian,
thank you for your answer.
What is the easiest way to do that, considering that I just need to turn that into an EString?
Follow me on Twitter @andreasindico
Re: first and last character truncated in STRING terminals [message #943179 is a reply to message #943172] Sun, 14 October 2012 08:15 Go to previous messageGo to next message
then simply do a one to one mapping in the valueconverter.
http://www.eclipse.org/Xtext/documentation.html#valueconverter
(ovveride org.eclipse.xtext.common.services.DefaultTerminalConverters.STRING())
~Christian
Re: first and last character truncated in STRING terminals [message #943187 is a reply to message #943179] Sun, 14 October 2012 08:27 Go to previous messageGo to next message
I am diving into the DefaultTerminalConverters in order to see how the STRING conversion was made and properly ovverride it. However I see the string conversion is delegated to an injected object (stringValueConverter). Where is that defined ? Xtext's architecture is so well made and so loose coupled that I can't find where things are actually done Smile
Re: first and last character truncated in STRING terminals [message #943188 is a reply to message #943187] Sun, 14 October 2012 08:28 Go to previous messageGo to next message
Ok My bad I had to check here package org.eclipse.xtext.conversion.impl;
for the StringValueConverter Class
I guess I also need the AbstractLexerBasedConverter ?
Re: first and last character truncated in STRING terminals [message #943192 is a reply to message #943188] Sun, 14 October 2012 08:31 Go to previous messageGo to next message
simply do something similar to the class org.eclipse.xtext.conversion.impl.STRINGValueConverter
Re: first and last character truncated in STRING terminals [message #943196 is a reply to message #943192] Sun, 14 October 2012 08:34 Go to previous messageGo to next message
OK now I have a class extending DefaultTerminalConverters and overriding its public IValueConverter<String> STRING() method.
Such method returns an instance of another self made class extending AbstractLexerBasedConverter<String> which basically does the same things of STRINGValueCoverter but it does not substring the original string.
No What do I have to do in the runtime module to make xtext using my own TerminalConverter?
Re: first and last character truncated in STRING terminals [message #943201 is a reply to message #943196] Sun, 14 October 2012 08:42 Go to previous messageGo to next message
Ok I can answer myself
public Class<? extends IValueConverterService>
bindIValueConverterService() {
return MyStringValueConverter.class;
in the RuntimeModule and it works perfectly
Re: first and last character truncated in STRING terminals [message #943202 is a reply to message #943196] Sun, 14 October 2012 08:42 Go to previous messageGo to next message
have a look at the existing binding and you will know what to do
	public Class<? extends org.eclipse.xtext.conversion.IValueConverterService> bindIValueConverterService() {
		return DefaultTerminalConverters.class;
~Christian
Re: first and last character truncated in STRING terminals [message #943203 is a reply to message #943201] Sun, 14 October 2012 08:43 Go to previous messageGo to next message
Christian Thank you again for your kind help!
Re: first and last character truncated in STRING terminals [message #943392 is a reply to message #943187] Sun, 14 October 2012 12:43 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
> actually done :)
Tip,
If injection is made via interface, look at the source for the interface
- see if it has a ImplementedBy annotation. That is the class that is
used unless there is a binding in the module(s) used to setup your langague.
Secondly, look the module for your language, open type hierarchy and
include all inherited methods. See if you find the class there.
Typically, I find it easier to just debug, set a breakpoint at look at
the class of the injected thing.
- henrik
Re: first and last character truncated in STRING terminals [message #959384 is a reply to message #943160] Fri, 26 October 2012 17:24 Go to previous messageGo to next message
Kokongi Nei is currently offline Kokongi NeiFriend
Andrea,
I am attempting to do the same thing--have a grammar that supports unquoted STRINGs. As the first step, I am overriding the terminal STRING as you did:
But, when I run the MWE2 Workflow, I get this error:
error(208): ../org.xtext.example.definitions/src-gen/org/xtext/example/definitions/parser/antlr/internal/InternalDefinitions.g:243:1: The following token definitions can never be matched because prior tokens match the same input: RULE_INT
I assume you had the same problem, and if so, what did you do?
Thanks!
Re: first and last character truncated in STRING terminals [message #960514 is a reply to message #959384] Sat, 27 October 2012 14:50 Go to previous message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Please refer to the section on terminal rules in the documentation. Your
STRING rule will basicly consume everything like ID and INTs since it is
defined with a higher priority (because the others are inherited).
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 26.10.12 19:24, schrieb Kokongi Nei:
> Andrea,
> STRING as you did:
> error(208):
> Thanks!
Previous Topic:Issue with inferred model and variable usage
Next Topic:pre-generate resource descriptions
Current Time: Sun May 16 06:52:27 GMT 2021
Powered by FUDForum. Page generated in 0.02779 seconds
