Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] Problem comparing identical GMF-resources
[EMF Compare] Problem comparing identical GMF-resources [message #130422] |
Sun, 26 October 2008 20:34 |
Martin Fluegge Messages: 141 Registered: July 2009 |
I have a problem when I compare two XML-files which contain a
GMF-Resource and the referenced EMF-Resource.
The GMF-Resource only contains a diagram, 2 Nodes an an Edge between
them. All objects have XMI-ids.
When I compare them programatically the comparison always finds an
"UpdateAttribute" in the Edge's BendPoints, but both XML-Files are
identically.
I am using EMF Compare 0.8.1.
Here is the source-code (maybe there is a bug in there)
----------- begin ----------
final ResourceSet modelResourceSet = new ResourceSetImpl();
modelResourceSet.getPackageRegistry().put("http://www.eclipse.org/gmf/runtime/1.0.1/notation",
NotationPackage.eINSTANCE);
modelResourceSet.getPackageRegistry().put("http://www.umleditor.de",
UmleditorPackage.eINSTANCE);
Resource resource1 = ModelUtils.load(
URI.createFileURI("Z:/compare/default2.umleditor_diagram"),
modelResourceSet).eResource();
Resource resource2 = ModelUtils.load(
new java.io.File("Z:/compare/default2.umleditor_diagram2"),
final MatchModel match = MatchService.doResourceMatch(resource1,
resource2, null);
// Detects differences
final DiffModel diff = DiffService.doDiff(match, false);
printChanges(diff);
---------- end -----------
When I run the code it always prints:
1 change(s) in Diagram default2.umleditor_diagram(class
org.eclipse.emf.compare.diff.metamodel.impl.DiffGroupImpl)
1 change(s) in Edge true(class
1 change(s) in RelativeBendpoints
[org.eclipse.gmf.runtime.notation.datatype.RelativeBendpoint@698403
(sourceX: -26, sourceY: 1, targetX: 123, targetY: 3),
org.eclipse.gmf.runtime.notation.datatype.RelativeBendpoint@15a0305
(sourceX: -149, sourceY: 18, targetX: 0, targetY: 20)](class
Attribute points in
(sourceX: -149, sourceY: 18, targetX: 0, targetY: 20)] has changed from
(sourceX: -149, sourceY: 18, targetX: 0, targetY: 20)] to
[org.eclipse.gmf.runtime.notation.datatype.RelativeBendpoint@1c247a0
org.eclipse.gmf.runtime.notation.datatype.RelativeBendpoint@1ec6696
org.eclipse.emf.compare.diff.metamodel.impl.UpdateAttributeI mpl)
Here is the resource-xml-file I am trying to compare:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation"
xmlns:umleditor="http://www.umleditor.de">
<umleditor:UMLDiagram xmi:id="_reTkIaOQEd2Eot2PsuBu8Q">
<Klassen xmi:type="umleditor:Klasse"
xmi:id="_N_KeMaOTEd23GO0a2WhQjA"
erbendeKlassen="_WB2iQKOTEd23GO0a2WhQjA" name="Martin"/>
xmi:id="_WB2iQKOTEd23GO0a2WhQjA" name="Max"/>
</umleditor:UMLDiagram>
<notation:Diagram xmi:id="_rfDLAKOQEd2Eot2PsuBu8Q" type="Dawn"
element="_reTkIaOQEd2Eot2PsuBu8Q" name="default2.umleditor_diagram"
measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_OAWxAKOTEd23GO0a2WhQjA"
type="1001" element="_N_KeMaOTEd23GO0a2WhQjA">
xmi:id="_OApr8KOTEd23GO0a2WhQjA" type="4001"/>
<styles xmi:type="notation:ShapeStyle"
xmi:id="_OAWxAaOTEd23GO0a2WhQjA"/>
<layoutConstraint xmi:type="notation:Bounds"
xmi:id="_OAWxAqOTEd23GO0a2WhQjA" x="200" y="125"/>
</children>
<children xmi:type="notation:Node" xmi:id="_VRuF0KOTEd22PaIR9R_YyQ"
type="1001" element="_WB2iQKOTEd23GO0a2WhQjA">
xmi:id="_WCcYI6OTEd23GO0a2WhQjA" type="4001"/>
xmi:id="_WCcYIaOTEd23GO0a2WhQjA"/>
xmi:id="_WCcYIqOTEd23GO0a2WhQjA" x="57" y="123"/>
</children>
<styles xmi:type="notation:DiagramStyle"
xmi:id="_bk4X4aOREd21ceEQVasm_Q"/>
<edges xmi:type="notation:Edge" xmi:id="_dm4Z8KOTEd23GO0a2WhQjA"
type="3001" source="_OAWxAKOTEd23GO0a2WhQjA"
target="_VRuF0KOTEd22PaIR9R_YyQ">
<styles xmi:type="notation:ConnectorStyle"
xmi:id="_dm4Z8aOTEd23GO0a2WhQjA"/>
<styles xmi:type="notation:FontStyle"
xmi:id="_dm4Z8qOTEd23GO0a2WhQjA"/>
<element xsi:nil="true"/>
<bendpoints xmi:type="notation:RelativeBendpoints"
xmi:id="_dm4Z86OTEd23GO0a2WhQjA" points="[-26, 1, 123, 3]$[-149, 18, 0,
20]"/>
</edges>
</notation:Diagram>
</xmi:XMI>
When I change the code to match the same resource-object (
MatchService.doResourceMatch(resource1, resource1, null);) there is no
change found. So it seems that the objects are not matched by xmi-id but
it's adress.
After searching I found this
bugzilla:https://bugs.eclipse.org/bugs/show_bug.cgi?id=24216 4
Maybe this problem is related to mine?
I am quite new the to world of Eclipse-Frameworks so I am not sure
whether the problem is a normal behavior, a bug or my mistake.
Thanks a lot in advance.
Best Regards,
Martin
Re: [EMF Compare] Problem comparing identical GMF-resources [message #130448 is a reply to message #130422] |
Mon, 27 October 2008 10:35 |
--------------090304040204010105080408
Hi Martin,
References are not compared structurally but by instance equality for
now, so the problems might come from that. This is the issue for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242165 as well as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244000 for example. This
is the highest bug in our priority list.
Another issue would be if your bendpoints do not have the same XMI ID :
you should then pass EMF Compare the option not to skip structural
comparison if XMI IDs differ :
resource2, null);
Should then be changed to
final Map<String, Object> options = new HashMap<String, Object>();
options.put(MatchOptions.OPTION_IGNORE_XMI_ID, Boolean.TRUE);
resource2, options);
If that does not help, you'll have to wait till we manage to fix the
aforementionned bug :(. Sorry for the inconvenience.
Laurent Goubet
Obeo
Martin Fl
Re: [EMF Compare] Problem comparing identical GMF-resources [message #130462 is a reply to message #130448] |
Mon, 27 October 2008 14:24 |
Hi Laurent,
thanks for your quick response. If the references are compared by
instance than now I understand why there is always a change detected.
In my project the xmi-ids are the only identifier for objects, so I'll
just wait until the feature is implemented.
Thanks again for your help and your good work. :)
Martin
laurent Goubet schrieb:
> Hi Martin,
> resource2, null);
> Laurent Goubet
> Obeo
> Martin Flügge a écrit :
>> Hi,
>> identically.
>> new
>> resource2, null);
>> printChanges(diff);
>> Attribute points in
>> <?xml version="1.0" encoding="UTF-8"?>
>> </children>
>> </children>
>> 20]"/>
>> </edges>
>> </notation:Diagram>
>> </xmi:XMI>
>> it's adress.
>> Best Regards,
>> Martin
Re: [EMF Compare] Problem comparing identical GMF-resources [message #620369 is a reply to message #130422] |
Hi Martin,
resource2, null);
Laurent Goubet
Obeo
Martin Fl
Re: [EMF Compare] Problem comparing identical GMF-resources [message #620370 is a reply to message #130448] |
Hi Laurent,
Martin
> Hi Martin,
> resource2, null);
> Laurent Goubet
> Obeo
>> Hi,
>> identically.
>> new
>> resource2, null);
>> printChanges(diff);
>> Attribute points in
>> </children>
>> </children>
>> 20]"/>
>> </edges>
>> </notation:Diagram>
>> </xmi:XMI>
>> it's adress.
>> Best Regards,
>> Martin
Current Time: Thu Apr 25 17:51:59 GMT 2024
Powered by FUDForum. Page generated in 0.02870 seconds
