Home » Modeling » Graphiti » SWTBot and Graphiti
SWTBot and Graphiti [message #942674] Sat, 13 October 2012 19:32 Go to next message
Junior Lekane Nimpa is currently offline Junior Lekane NimpaFriend
Hello all,
i have just one question.
Is it possible to test a graphiti editor with SWTBot?
Junior
Re: SWTBot and Graphiti [message #943476 is a reply to message #942674] Sun, 14 October 2012 14:52 Go to previous messageGo to next message
Andreas Graf is currently offline Andreas GrafFriend
Yes, on Eclipse Indigo, but SWTBot does seem to have a problem with Eclipse Juno.
Re: SWTBot and Graphiti [message #944811 is a reply to message #943476] Mon, 15 October 2012 05:48 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Which problems? We use it to test the Graphiti framework itself and it works
for us with Juno.
Michael
Re: SWTBot and Graphiti [message #944869 is a reply to message #942674] Mon, 15 October 2012 06:27 Go to previous messageGo to next message
Matthias Gorning is currently offline Matthias GorningFriend
Member
Samples can be found in the plugin "org.eclipse.graphiti.bot.tests"
BR,
Matthias
Re: SWTBot and Graphiti [message #945481 is a reply to message #944811] Mon, 15 October 2012 12:15 Go to previous messageGo to next message
I had problems after switching to Juno which I blamed on http://www.eclipse.org/forums/index.php/m/899339/
However, I have now switched to testing my functionality with dark feature processing a lot, so I have not tried recently.
Andreas
Re: SWTBot and Graphiti [message #946706 is a reply to message #945481] Tue, 16 October 2012 12:27 Go to previous messageGo to next message
Hello all,
where do I get the source code of the plugin
"org.eclipse.graphiti.bot.tests"?
I have the Graphiti SDK , but the above plugin is not contained .
Thanks a lot
Junior
Re: SWTBot and Graphiti [message #946833 is a reply to message #946706] Tue, 16 October 2012 14:52 Go to previous messageGo to next message
Hello Micheal,
you said that
SWTBot was used to test Graphiti under juno.
But i would like to know, which version of Juno you used to do the tests?
I use currently EClipse 4.2 and i can not test anything with SWTBot.
I am reading through the tutorial of Chris Aniszczyk, and the statement
bot.menu("File");
yield to the exception :
org.eclipse.swtbot.swt.exceptions.WidgetNotFoundException.
So I don't know, if I do something wrong or I should set something.
Did you used a specific setting?
Can someone give an hint?
Thanks a lot.
Junior
Re: SWTBot and Graphiti [message #946910 is a reply to message #946833] Tue, 16 October 2012 16:17 Go to previous messageGo to next message
Hi "Junior",
have a look at the bugzilla that I posted two posts above.
Andreas
Re: SWTBot and Graphiti [message #947597 is a reply to message #946706] Wed, 17 October 2012 08:20 Go to previous messageGo to next message
Junior,
you can find the sources of that plugin in our git repo at
http://git.eclipse.org/c/gmp/org.eclipse.gmp.graphiti.git/tree/tests/org.eclipse.graphiti.bot.tests
Michael
Re: SWTBot and Graphiti [message #947598 is a reply to message #946833] Wed, 17 October 2012 08:23 Go to previous message
Junior,
we use Eclipse 4.2 for our build and also the tests run against that
version. I can't remember changing any settings when we switched running our
tests from 3.7/3.8 to 4.2.
Michael
Previous Topic:FreeFormConnection and flexibility
Next Topic:Couple Graphiti Editor with XText DSL
Current Time: Tue Apr 16 15:07:51 GMT 2024
Powered by FUDForum. Page generated in 0.05578 seconds
