Home » Archived » Visual Editor (VE) » Placing logger call
Placing logger call [message #130378] Fri, 25 August 2006 12:35 Go to next message
I have to place a permanent logger debug call before swingutilities
invokelater paragraph. By doing this, am I violating any java coding
rules, standards, or conventions that would make eclipse and ve not work
right?
Re: Placing logger call [message #130439 is a reply to message #130378] Fri, 25 August 2006 14:48 Go to previous messageGo to next message
What kind of call is this? Do you mean you are changing SwingUtilities
itself, or just putting this call before your own code that is calling
SwingUtilities?
> right?
Rich Kulp
Re: Placing logger call [message #130452 is a reply to message #130439] Fri, 25 August 2006 20:02 Go to previous messageGo to next message
the code is an apache logj4xml logger. if i insert my code before
invokelater paragraph, would it cause any problems with eclipse and ve? in
some other editors, they do not want you to modify their auto generated
code. that is why I asking.
// TODO Auto-generated method stub
logger.debug(""); <--- my code
SwingUtilities.invokeLater(new Runnable() {
public void run() {
RTMonitor application = new RTMonitor();
application.getJFrame().setVisible(true);
Re: Placing logger call [message #130464 is a reply to message #130452] Mon, 28 August 2006 09:35 Go to previous messageGo to next message
Is it is safe to insert the logger before invokelater statement?
Re: Placing logger call [message #130474 is a reply to message #130464] Mon, 28 August 2006 10:20 Go to previous messageGo to next message
You can insert code just about anywhere. Especially if it is not a
setter of a property. Most such code is ignored.
Rich Kulp
Re: Placing logger call [message #130484 is a reply to message #130474] Mon, 28 August 2006 10:28 Go to previous message
thanks.
Re: Placing logger call [message #614580 is a reply to message #130378] Fri, 25 August 2006 14:48 Go to previous message
SwingUtilities?
> right?
Rich Kulp
Re: Placing logger call [message #614581 is a reply to message #130439] Fri, 25 August 2006 20:02 Go to previous message
public void run() {
Re: Placing logger call [message #614582 is a reply to message #130452] Mon, 28 August 2006 09:35 Go to previous message
Re: Placing logger call [message #614583 is a reply to message #130464] Mon, 28 August 2006 10:20 Go to previous message
Rich Kulp
Re: Placing logger call [message #614584 is a reply to message #130474] Mon, 28 August 2006 10:28 Go to previous message
thanks.
Previous Topic:Refreshing after correcting errors
Next Topic:VE Problem in Eclipse 3.2
Current Time: Thu Jul 17 03:31:18 EDT 2025
Powered by FUDForum. Page generated in 0.10030 seconds
