AC on Linux (Ubuntu 8.04) symbol lookup error: ./../lib/libtptpUtils.so.4: undefined symbol: __ti3io [message #130376] |
Thu, 22 May 2008 14:08 |
Originally posted by: dennis.brains2b.org
Dear all,
I'm running into a problem trying to start either IAC or AC on a Linux machie.
Starting it manually gives me the following error : symbol lookup error: ./../lib/libtptpUtils.so.4: undefined symbol: __ti3ios.
Versions:
Ubuntu 8.04 (Hardy)
Eclipse 3.3 (Europe)
Java 1.5.0_12
AC agent version 4.4 and 4.5 both give the same problem.
Can someone think of possible causes of this problem and/or solutions?
Thanks.
Dennis..
Re: AC on Linux (Ubuntu 8.04) symbol lookup error: [message #131549 is a reply to message #130402] |
Mon, 23 June 2008 12:56 |
>dennis wrote at Thu, 22 May 2008 14:08:15 +0000:
>> Dear all,
>> machie. Starting it manually gives me the following error : symbol
>> Versions:
>> Ubuntu 8.04 (Hardy)
>> Java 1.5.0_12
>> Thanks.
>> Dennis..
>Hi Dennis,
>please follow the below steps:
>1, installing the necessary library:
>$ sudo apt-get install libstdc++2.10-glibc2.2
>2, setting some environment variables: (assume AC is installed at /opt/
>tptpdc)
>$ export PATH=$PATH:/opt/tptpdc/bin
>$ export TEMP=/tmp
>$ export LD_LIBRARY_PATH=/opt/tptpdc/lib
>OK, you can run SetConfig.sh, and then run ACStart.sh to start the Agent
>Controller.
>-Richard.
Dear Richard,
Sorry for the late reply, but I was away from my systems. The problem is that Hardy (Ubuntu 8.04) does not include
libstdc++2.10-glibc2.2 and I cannot find another library that includes the __ti3ios symbol.
Dennis
FUDForum. Page generated in 0.02939 seconds
