Home » Eclipse Projects » Remote Application Platform (RAP) » FormText in standalone RWT
FormText in standalone RWT [message #130256] |
Sun, 26 April 2009 15:32 |
Originally posted by: peterka.jiri.gmail.com
I would like to use FormText widget available in M6
(org.eclipse.ui.forms.widgets) but an exception is always thrown. It
seems it depends on RAP platform and can't be used separated.
There is always this error:
Could not evaluate javascript response
TypeError: org.eclipse.ui is undefined
org.eclipse.swt.EventUtil.suspendEventHandling()...
The server session timed out
Is there any way howto use it in RWT application? And if so, how and
which additional libraries must be included except ui.forms?
Best regards
Jiri
Re: FormText in standalone RWT [message #130269 is a reply to message #130256] |
Sun, 26 April 2009 17:58 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Jiri,
look at the org.eclipse.rap.ui.forms\META-INF\MANIFEST.MF for the plugin
dependencies. You need:
org.eclipse.core.runtime,
org.eclipse.rap.jface,
org.eclipse.rap.ui
and these packages too:
com.ibm.icu.text,
javax.xml.parsers,
org.w3c.dom,
org.xml.sax
Best,
Ivan
Jiri Peterka wrote:
> Best regards
> Jiri
Re: FormText in standalone RWT [message #130434 is a reply to message #130269] |
Mon, 27 April 2009 18:33 |
Hi Ivan,
I've added all of those jars, but still have problem to add hyperlink
into a form (see this snippet)
This works:
FormToolkit toolkit = new FormToolkit(composite.getDisplay());
Form form = toolkit.createForm(composite);
form.setText("Snippet2");
TableWrapLayout layout = new TableWrapLayout();
form.getBody().setLayout(layout);
toolkit.createLabel(form.getBody(), "Snippet2");
This doesn't:
Hyperlink link = toolkit.createHyperlink(form.getBody(),
"Click", SWT.NONE);
It threw this error:
org.eclipse.swt.EventUtil.suspendEventHandling();var req =
org.eclipse.swt.Request.getInstance();req.setRequestCounter( "0"
);qx.theme.manager.Meta.getInstance().setTheme(
org.eclipse.swt.theme.Custom_1
);org.eclipse.swt.Request.getInstance().setTimeoutPage( "
The server session timed out.
If it's possible could you direct me direct to the working piece of code
with hyperlink, <li> tags, etc.
I was trying samples from this article -
http://www.ibm.com/developerworks/opensource/library/os-ecli pse-forms/
but I was almost always unsuccessful.
Best regards
Jiri
Ivan Furnadjiev wrote:
> Hi Jiri,
> org.eclipse.rap.ui
> com.ibm.icu.text,
> javax.xml.parsers,
> org.w3c.dom,
> org.xml.sax
> Best,
> Ivan
> Jiri Peterka wrote:
>> Hi,
>> Best regards
>> Jiri
Re: FormText in standalone RWT [message #130447 is a reply to message #130434] |
Mon, 27 April 2009 18:58 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Jiri,
as forms plug-in is intended to work with RAP, but not RWT
standalone, it makes use of the resource extension point.
You could try to register these resources manually. Have a look at
the resources extensions in the plugin.xml.
HTH
Rüdiger
Jiri Peterka wrote:
> Hi Ivan,
> This works:
> This doesn't:
> "Click", SWT.NONE);
> Best regards
> Jiri
>> Hi Jiri,
>> plugin dependencies. You need:
>> org.eclipse.rap.ui
>> com.ibm.icu.text,
>> javax.xml.parsers,
>> org.w3c.dom,
>> org.xml.sax
>> Best,
>> Ivan
>> Jiri Peterka wrote:
>>> Hi,
>>> Best regards
>>> Jiri
Re: FormText in standalone RWT [message #130485 is a reply to message #130447] |
Tue, 28 April 2009 10:03 |
Originally posted by: markus.wolf.nmmn.com
Hi Jiri,
you could setup the forms plugin with this code in a
ServletContextListener on application startup:
final ResourceLoader rl = new ResourceLoader() {
public InputStream getResourceAsStream(final String resourceName)
throws IOException {
return getClass().getClassLoader().getResourceAsStream(
resourceName);
final ThemeManager tm = ThemeManager.getInstance();
tm.addThemeableWidget(Hyperlink.class, rl);
tm.addThemeableWidget(FormText.class, rl);
Markus Wolf
> Jiri,
> as forms plug-in is intended to work with RAP, but not RWT standalone,
> You could try to register these resources manually. Have a look at the
> HTH
> Rüdiger
> Jiri Peterka wrote:
>> Hi Ivan,
>> This works:
>> This doesn't:
>> "Click", SWT.NONE);
>> code with hyperlink, <li> tags, etc.
>> Best regards
>> Jiri
>>> Hi Jiri,
>>> org.eclipse.rap.ui
>>> com.ibm.icu.text,
>>> javax.xml.parsers,
>>> org.w3c.dom,
>>> org.xml.sax
>>> Best,
>>> Ivan
>>> Jiri Peterka wrote:
>>>> Hi,
>>>> Best regards
>>>> Jiri
NMMN - New Media Markets & Networks GmbH
Geschäftsführung: Kfm. Michael Schütt
Finanzamt HH-Altona UStID DE 812 699 852 HRB 71102 Hamburg
HypoVereinsbank - BLZ 200 300 00 - Konto-Nr. 156 29 82
http://www.nmmn.com Tel.: +49 40 284 118 -0
Langbehnstrasse 6 Entwicklung: -720
22761 Hamburg Fax: -999
Re: FormText in standalone RWT [message #1744565 is a reply to message #130485] |
Wed, 28 September 2016 11:15 |
I have the same problem and I'm building standalone apps using RAP 3.1.0, I've tried your suggestions, but did not work.
public class SpringRWTServletContextListener implements ServletContextListener
public void contextInitialized(ServletContextEvent event)
final ResourceLoader loader = new ResourceLoader()
public InputStream getResourceAsStream(String resourceName) throws IOException
return getClass().getClassLoader().getResourceAsStream(resourceName);
final ThemeManager themeManager = new ThemeManager();
themeManager.addThemeableWidget(Hyperlink.class.getName(), loader);
public void contextDestroyed(ServletContextEvent event){}
Thanks & Regards,
SetNug
Current Time: Tue Apr 23 17:55:04 GMT 2024
Powered by FUDForum. Page generated in 0.03515 seconds
