Home » Modeling » QVT-OML » Possibility to generate Circular Referenced target model
Possibility to generate Circular Referenced target model [message #941147] Fri, 12 October 2012 08:45 Go to next message
Alexander Unsonamed is currently offline Alexander UnsonamedFriend
Is it possible to somehow handle Circular References?
My source model has circular references, and I'd like to have circular references in generated target model.
E.g.:
result.name := "Model";
var box: Box := object Box {
	name := "Box node";
var subBox : Box := object Box {
	name := "SubBox";
result.root := box;
box.children += subBox;
subBox.children += box;
So, I have Box with child of type Box. Thus I have possibility to create infinite nesting of boxes.
As a result of transformation, I have result object without any children.
If I remove the following statement:
transformation works well, but I get predefined 1-level nesting.
Re: Possibility to generate Circular Referenced target model [message #941208 is a reply to message #941147] Fri, 12 October 2012 09:46 Go to previous messageGo to next message
It's certainly possible, but QVTo is only partially declarative so you
need to empathize with its imperative actions.
A circular loop cannot naturally be created in a single regular pass.
Rather than ensuring the referential validity of each loop step and
having a special loop closing step, I recommend what I usually find
necessary in QVTo; code in two passes.
Pass 1 creates the output as a tree, and populates an in2out Dict.
Pass 2 adds cross-references to the tree using the in2out Dict from pass 1.
[If you're clever/lucky you can use 'resolve' in place of the Doct, but
I find resolve hard to understand/debug in practice.]
Ed Willink
> E.g.:
> name := "Box node";
> name := "SubBox";
> result.root := box;
Re: Possibility to generate Circular Referenced target model [message #944828 is a reply to message #941208] Mon, 15 October 2012 06:03 Go to previous messageGo to next message
Thanks for the comment, but I really don't understand what you meant by in2out Dict. What am I supposed to store in such a dictionary and why it cannot be created by one pass?
Can you supply me with the simplest example, it would be nice.
Thanks in advance.
Re: Possibility to generate Circular Referenced target model [message #944881 is a reply to message #944828] Mon, 15 October 2012 06:32 Go to previous message
Take the simplest of trees with links
A
B, link to C
C, link to B
This can be constructed in containment order
create A
create B
create C
then crossreferenced
assign B link to C
assign C link to B
since when assigning cross references all sources and targets exist.
Cannot be done in one pass.
If A, B, C result from a transformation on a, b, c then in2out Dict contains
a => A
b => B
c => C
Ed Willink
On 15/10/2012 07:03, Alexander Unsonamed wrote:
> Quote:
>> pass 1.
> Thanks in advance.
Previous Topic:Resolve EValues from a qvtotrace file
Next Topic:How to manually register blackbox units?
Current Time: Sat Dec 03 06:08:34 GMT 2022
Powered by FUDForum. Page generated in 0.02393 seconds
