Eclipse debug perspective issue with required report parameters [message #941039] |
Fri, 12 October 2012 06:59  |
donino donino Messages: 183 Registered: July 2011 |
I never used the Eclipse debug perpspective, i wanted to give it a try in version 4.2.1 for my javascript event handlers. i followed this wiki:
- Open debug perspective
- Run->debug configurations->Add a report configuration
- I did not change the configuration suggested, so "run and render" mode
When i click on "debug" it opens the report parameter dialog, but i can't run the report, i get this exception for the first required parameter: "Value of required parameter [Year] is not specified", whatever i do.
Though this report hasn't errors and runs correctly in the report design perspective.
I tried various debug configurations with a same result. Did i miss something? Is there a way to workaround this issue?
[Updated on: Fri, 12 October 2012 07:03] Report message to a moderator
FUDForum. Page generated in 0.02062 seconds
