Home » Eclipse Projects » Equinox » tearing out my hair trying to start the framework.
tearing out my hair trying to start the framework. [message #129753] Wed, 22 April 2009 18:41 Go to next message
I'm getting this exception:
Exception in thread "main" java.lang.NoClassDefFoundError:
org.eclipse.osgi.internal.composite.CompositeImpl
at java.lang.J9VMInternals.verifyImpl(Native Method)
at java.lang.J9VMInternals.verify(J9VMInternals.java:68)
at java.lang.J9VMInternals.verify(J9VMInternals.java:66)
at java.lang.J9VMInternals.initialize(J9VMInternals.java:129)
at
org.eclipse.osgi.framework.internal.core.Framework.createSys temBundle(Framework.java:280)
at
org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:223)
at
org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:157)
at
org.eclipse.osgi.framework.internal.core.EquinoxLauncher.int ernalInit(EquinoxLauncher.java:68)
at
org.eclipse.osgi.framework.internal.core.EquinoxLauncher.int ernalStart(EquinoxLauncher.java:274)
at
org.eclipse.osgi.framework.internal.core.EquinoxLauncher.sta rt(EquinoxLauncher.java:251)
Caused by: java.lang.ClassNotFoundException:
at java.net.URLClassLoader.findClass(URLClassLoader.java:496)
at
org.eclipse.osgi.launch.EquinoxFWClassLoader.loadClass(Equin oxFWClassLoader.java:38)
at java.lang.ClassLoader.loadClass(ClassLoader.java:597)
I can't find any reference to this CompositeImpl thing ANYWHERE. I'm
not trying to start anything in a UI, I'm just trying to start the
framework from inside of a java main(). My ultimate goal is to run the
framework code inside a SOAP service under WebSphere, but I can't even
get it to run from a java command line app. :(
Any help is much appreciated.
Jason Henriksen
Re: tearing out my hair trying to start the framework. [message #129823 is a reply to message #129753] Thu, 23 April 2009 11:03 Go to previous messageGo to next message
I also get this problem when trying from here:
at
at
at
at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:286)
So the either way I try to start the framework I get an error.
Please help if you can. If I can't start the framework I'll have to set
Equinox aside for a while. :(
Jason
Re: tearing out my hair trying to start the framework. [message #1828303 is a reply to message #129823] Sat, 06 June 2020 14:37 Go to previous message
tearing out my long bob hair trying to start the framew
at
at
at
at
Previous Topic:P2 Director fails to resolve Java 11 dependency
Next Topic:No copyright or license information for feature-based product
Current Time: Sat Mar 15 14:28:30 EDT 2025
Powered by FUDForum. Page generated in 0.03339 seconds
