Re: Update from built sources [message #938267 is a reply to message #938262] |
Tue, 09 October 2012 18:17 |
Hey Denis,
You don't have repository/target at all?
Adding features/... should have worked, what are the dependencies that are missing? I would suspect that you are trying to update from 0.8 to "0.9 master" which needs new stuff that is not available as part of the p2 repo built in features/... (but should be in repository/...)
Benjamin
My blog: http://blog.benjamin-cabe.com
Re: Update from built sources [message #938675 is a reply to message #938267] |
Wed, 10 October 2012 04:00 |
Denis Artemov Messages: 38 Registered: September 2012 |
Member |
Benjamin Cabe wrote on Tue, 09 October 2012 14:17Hey Denis,
"repository/target" is local folders in LDT directory which apears afrer build, right? I have only "repository" root-directory with category.xml and pom.xml files in it and "target-platform" root-directory with ldt.target and pom.xml files.
Benjamin Cabe wrote on Tue, 09 October 2012 14:17Adding features/... should have worked, what are the dependencies that are missing? I would suspect that you are trying to update from 0.8 to "0.9 master"
I tried to update from last 0.9 and I got this message:
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.naef.jnlua,0.9.1.201210091735
No repository found containing: osgi.bundle,com.naef.jnlua.windows,0.9.1.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt,0.9.0.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.debug.core,0.9.0.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.debug.ui,0.9.0.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.doc.user,0.9.0.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.metalua,0.9.0.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.metalua.32bits,0.9.0.201210091735
No repository found containing: osgi.bundle,org.eclipse.koneki.ldt.ui,0.9.0.201210091735
No repository found containing: org.eclipse.update.feature,org.eclipse.koneki.ldt,0.9.0.201210091735
I was wrong before. It is no message about dependencies...
Re: Update from built sources [message #939894 is a reply to message #939337] |
Thu, 11 October 2012 05:51 |
Member |
Kevin KIN-FOO wrote on Wed, 10 October 2012 13:01Yes it is,
Check the content of features/org.eclipse.koneki.ldt.product-feature/target/site/
This doesn't work for me. It stops with message
Your original request has been modified.
"Add-on Function for p2" is already installed, so an update will be performed instead.
"Dynamic Languages Toolkit - Core Frameworks" is already present because other installed software requires it. It will be added to the installed software list.
"Eclipse Help System" is already installed, so an update will be performed instead.
"Eclipse Platform" is already installed, so an update will be performed instead.
"Eclipse RCP" is already installed, so an update will be performed instead.
"EMF - Eclipse Modeling Framework Core Runtime" is already installed, so an update will be performed instead.
"EMF Common" is already installed, so an update will be performed instead.
"Equinox p2 Core Function" is already installed, so an update will be performed instead.
"Equinox p2 Provisioning for IDEs." is already installed, so an update will be performed instead.
"Equinox p2 RCP Management Facilities" is already installed, so an update will be performed instead.
"Lua Development Tools (Incubation)" is already installed, so an update will be performed instead.
"Lua Development Tools - branding (Incubation)" is already installed, so an update will be performed instead.
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse e4 Rich Client Platform 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj (org.eclipse.e4.rcp.feature.group 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj)
Software currently installed: Lua Development Tools Product (Incubation) 0.9.0.201210101448 (org.eclipse.koneki.ldt.product-product 0.9.0.201210101448)
Only one of the following can be installed at once:
Simple Configurator 1.0.200.v20110815-1438 (org.eclipse.equinox.simpleconfigurator 1.0.200.v20110815-1438)
Simple Configurator 1.0.301.v20120828-033635 (org.eclipse.equinox.simpleconfigurator 1.0.301.v20120828-033635)
Simple Configurator 1.0.300.v20110815-1744 (org.eclipse.equinox.simpleconfigurator 1.0.300.v20110815-1744)
Cannot satisfy dependency:
From: Eclipse e4 Rich Client Platform 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj (org.eclipse.e4.rcp.feature.group 1.1.0.v20120521-2329-8yFTIGIbGGduEZ6-7-jLx41nXj)
To: org.eclipse.equinox.simpleconfigurator [1.0.301.v20120828-033635]
From: Lua Development Tools Product (Incubation) 0.9.0.201210101448 (org.eclipse.koneki.ldt.product-product 0.9.0.201210101448)
To: org.eclipse.koneki.ldt.product.feature.group [0.9.0.201210101448]
From: Lua Development Tools - branding (Incubation) 0.9.0.201210101448 (org.eclipse.koneki.ldt.product.feature.group 0.9.0.201210101448)
To: org.eclipse.platform.feature.group [3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q]
From: Eclipse Platform 3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q (org.eclipse.platform.feature.group 3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q)
To: org.eclipse.rcp.feature.group [3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272]
From: Eclipse RCP 3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272 (org.eclipse.rcp.feature.group 3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272)
To: org.eclipse.equinox.simpleconfigurator [1.0.200.v20110815-1438]
FUDForum. Page generated in 0.03883 seconds
