Re: Browser window title and favicon on RWT level [message #129349 is a reply to message #129262] |
Wed, 22 April 2009 08:15 |
Originally posted by: markus.wolf.nmmn.com
Hi Jiri,
> I followed this steps, wrote own implementation of AbstractBranding and
> this class is instantiated when app is executed. But getTitle() and
> other methods are never called.
> Don't you know what's wrong? (URL, some other details, etc.)?
You should define the following to get this working:
<context-param>
<param-name>org.eclipse.rwt.themes</param-name>
<param-value>my-theme#my-theme.css</param-value>
</context-param>
<context-param>
<param-name>org.eclipse.rwt.brandings</param-name>
<param-value>example.Branding</param-value>
</context-param>
Then you need a file my-theme.css in your root classpath and the class
'example.Branding'. This class must extend the AbstractBranding class of
RWT and override the following methods:
* getServletName() - this must return the servlet mapping url but
without leading slash
* getFavIcon() - this should return the path to the favicon you want to use
* getTitle() - this should return the page title you want to display
* getThemeId() - this should return 'my-theme' as specified in the
web.xml before the dash
Hope that helps :)
Markus
> Jiri
> Markus Wolf wrote:
>> Hi Jiri
>>> is there a way howto set Browser window title and flavicon from RWT
>>> application?
>> in the FAQ is explained on how to create an RWT application:
>> http://wiki.eclipse.org/RAP/FAQ#How_do_I_use_a_RWT_standalon e_application_in_Tomcat
>> With the branding you can define your requested aspects.
>> Regards
>> Markus Wolf
NMMN - New Media Markets & Networks GmbH
Geschäftsführung: Kfm. Michael Schütt
Finanzamt HH-Altona UStID DE 812 699 852 HRB 71102 Hamburg
HypoVereinsbank - BLZ 200 300 00 - Konto-Nr. 156 29 82
http://www.nmmn.com Tel.: +49 40 284 118 -0
Langbehnstrasse 6 Entwicklung: -720
22761 Hamburg Fax: -999
Re: Browser window title and favicon on RWT level [message #129478 is a reply to message #129349] |
Wed, 22 April 2009 17:05 |
Originally posted by: peterka.jiri.gmail.com
Hi Markus,
thanks for detailed instructions. Nevertheless I've got still the same
problem. getServletName() is called twice and nothing more.
I've tried servlet name in getServletName() as
localhost:8180/rapServlet" or "localhost:8180/ServletTest/rapServlet",...
Web.xml servlet is defined like this:
<servlet>
<servlet-name>rapServlet</servlet-name>
<servlet-class>org.eclipse.rwt.internal.engine.RWTDelegate</servlet-class >
</servlet>
<servlet-mapping>
<url-pattern>/index.html</url-pattern>
</servlet-mapping>
Finally URL is http://localhost:8180/ServletTest where "ServletTest" is
Project name in Eclipse. I'm little bit confused with this mapping.
Any idea is welcome. (RAP 1.2 M6)
Best regards
Jiri
Markus Wolf wrote:
> Hi Jiri,
> <context-param>
> </context-param>
> <context-param>
> </context-param>
> Hope that helps :)
> Regards
> Markus
>> Jiri
>> Markus Wolf wrote:
>>> Hi Jiri
>>>> application?
>>> Regards
>>> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129491 is a reply to message #129478] |
Wed, 22 April 2009 17:18 |
Hi Jiri,
> <servlet>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
You specified '/index.html' as mapped servlet. Therefore using
'index.html' in your Binding as getServletName() should work.
Markus
> Best regards
> Jiri
> Markus Wolf wrote:
>> Hi Jiri,
>> <context-param>
>> </context-param>
>> <context-param>
>> </context-param>
>> to use
>> Hope that helps :)
>> Regards
>> Markus
>>> Jiri
>>> Markus Wolf wrote:
>>>> Hi Jiri
>>>>> application?
>>>> Regards
>>>> Markus Wolf
Re: Browser window title and favicon on RWT level [message #129504 is a reply to message #129491] |
Wed, 22 April 2009 17:33 |
Markus, thanks, you're the man! Now it works great :).
Jiri
Markus Wolf wrote:
> Hi Jiri,
>> <servlet>
>> </servlet>
>> <servlet-mapping>
>> </servlet-mapping>
> Regards
> Markus
>> Best regards
>> Jiri
>> Markus Wolf wrote:
>>> Hi Jiri,
>>> <context-param>
>>> </context-param>
>>> <context-param>
>>> </context-param>
>>> to use
>>> Hope that helps :)
>>> Regards
>>> Markus
>>>> Jiri
>>>> Markus Wolf wrote:
>>>>> Hi Jiri
>>>>>> application?
>>>>> Regards
>>>>> Markus Wolf
FUDForum. Page generated in 0.04265 seconds
