Home » Eclipse Projects » Remote Application Platform (RAP) » ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out
Re: ActionFactory CUT,COPY, PASTE, ABOUT, PRINT Commented out [message #128652 is a reply to message #128614] |
Mon, 20 April 2009 09:15 |
Markus rüger Messages: 369 Registered: July 2009 |
Thanks for the fast answer.
I know that the default behavior will not work, but retarget should be
possible.
I added a feature request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=272867
For the meantime, is it possible, to just comment the code in, or would this
lead to errors?
This way I could retarget these actions.
Ragards,
Markus
"Benjamin Muskalla" <bmuskalla@eclipsesource.com> schrieb im Newsbeitrag
news:gshd8i$k11$1@build.eclipse.org...
> Hi Markus,
> these were completely commented out as the default implementation can't be
> supported at the moment.
> CUT,COPY and PASTE are using the clipboard which is not yet available in
> RWT and may never be available due to browser restrictions.
> ABOUT is based on the whole Equinox product story which is not yet ready
> to be used on the server-side. We're investigating this at the moment.
> PRINT doesn't make much sense at the moment as we only have the Display
> implementation of device. I'm not sure if it makes sense to support this
> in the same way as RCP does or if it's even possible to have an
> alternative implementation behind the scenes.
> But I see your point that you want to retarget the action with your own
> implementation. This is a valid apporach and should be discussed further.
> Do you want to open a feature request?
> Just for your information: We will not be able to do this for 1.2 as we
> already have API freeze.
> Cheers
> Benny
> Markus Kr
Current Time: Thu Apr 25 09:24:52 GMT 2024
Powered by FUDForum. Page generated in 0.03333 seconds
