Cannot profile application [message #128541] |
Thu, 17 April 2008 10:12 |
Joerg Bullmann Messages: 6 Registered: July 2009 |
Hi there,
TPTP is letting me down (quite) a bit (or I am not clever enough). I'll
keep it short. I have now spent two days trying to get this to work and am
at the end of my tether.
I want to do memory analysis (and then also CPU profiling) of an
Ecplise-plugin based RCP application.
* Windows XP Pro SP2
* 2GB, 2.4 GHz Core 2 Duo
* Java 1.6.0_05
* Eclipse Europa 3.3.2 with latest TPTP 4.4.1 (updated via Eclipse
built-in updater)
* after a lot of failed attempts, I also installed all optionals mentioned
on the TPTP download page (BIRT, WST, GEF, ...); all of them installed via
Eclipse built-in updater)
* Stand Alone Agent Controller 4.4.1 (started trying this because the IAC
would not respond)
1) Stand alone agent controller
a) Installed agent controller.
b) SetConfig.bat'ed it.
c) Started it: ACServer.exe
d) Tried it out with: SampleClient.exe (no problem)
2) Start Eclipse
a) Disable IAC in the preferences
b) Disable proxy in Eclipse preferences (I need it to access the internet,
but I want to be sure it does not get in the way of TPTP)
3) Create a profiling run configuration (test-config). This run
configuration runs fine if I call it normally or debug it. It is a small
headless eclipse application that tests some of my code.
a) Add memory analysis
b) Save it
c) run the thing (I now see "Launching test-config" in the status line),
then after a while I get a dialog "Agent Controller is unavailable under
port 10006" with an exception:
org.eclipse.tptp.platform.execution.exceptions.NotConnectedE xception
Unable to get a reference to the agent. The Client is not connected to the
Agent Controller.
[.. stack trace ..]
Underneath above dialog, there is another (becomes visible when closing
the other one): "An unexpected error occurred while attempting to
establish a connection with the JVMTI agent.
Shown stack trace:
at
org.eclipse.tptp.platform.execution.client.core.internal.Con nectionImpl.addDataListener(ConnectionImpl.java:435)
at
org.eclipse.tptp.platform.execution.client.core.internal.Age ntController.addDataListener(AgentController.java:1272)
at
org.eclipse.tptp.platform.execution.client.agent.internal.Ag entImpl.addDataListener(AgentImpl.java:425)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.configureDataProcessor(TIDelegateHelper.java:7 60)
at
org.eclipse.tptp.platform.jvmti.client.internal.launcher.TID elegateHelper.attachToAgent(TIDelegateHelper.java:703)
[.. further stack trace ..]
4) Try out the Agent Controller: SampleClient.exe (no problem, again). Is
TPTP is lying to me?
5) Cry.
Can anyone help?
Please!
Joerg
Re: Cannot profile application [message #129054 is a reply to message #128541] |
Thu, 24 April 2008 21:28 |
Originally posted by: mike.bleazard.org
Joerg,
I've been battling with TPTP for a couple of days now as well. It hasn't
been a particularly pleasant experience.
I've also been unable to get Eclipse talking to the ACServer.exe. I did
find some information saying you need to switch the default port from
10002 to 10006. But this didn't work for me.
However, in desperation I tried running the ACWinServer.exe that's in
the same <install-directory>/bin as ACServer.exe. In a brief sweep of
the web I couldn't find any information at all on it - but when I did
run it, I found I was able to profile our RCP application.
The next thing to trip me up was that I didn't think I was getting any
data because nothing was appearing in my 'Object Allocations' view (the
view associated with Memory Analysis). I eventually discovered that it
was but there seems to be a bug with the default filter that just
filters out *all* the data. Grrrr. When I switched to 'No filter' all my
object allocation data appeared.
However, I'm not yet convinced that the results I'm seeing justify the
effort going in. Can anyone out there give me some encouragement that
it's worthwhile persisting?
Mike
Joerg Bullmann wrote:
> Hi there,
> am at the end of my tether.
> * Java 1.6.0_05
> built-in updater)
> mentioned on the TPTP download page (BIRT, WST, GEF, ...); all of them
> installed via Eclipse built-in updater)
> IAC would not respond)
> 2) Start Eclipse
> internet, but I want to be sure it does not get in the way of TPTP)
> b) Save it
> the Agent Controller.
> [.. stack trace ..]
> Shown stack trace:
> at
> at
> at
> at
> at
> Is TPTP is lying to me?
> 5) Cry.
> Can anyone help?
> Please!
> Joerg
Re: Cannot profile application [message #129114 is a reply to message #129054] |
Fri, 25 April 2008 09:59 |
A couple of corrections:
The exe is not called ACWinServer - but ACWInService.
And - it wasn't doing anything anyway. I've tried profiling my RCP app
again without ACWinService running - and the profiling is still working.
It must be using the IAC.
Mike Bleazard wrote:
> Joerg,
> Cheers,
> Mike
>> Hi there,
>> I'll keep it short. I have now spent two days trying to get this to
>> work and am at the end of my tether.
>> * Java 1.6.0_05
>> built-in updater)
>> 2) Start Eclipse
>> small headless eclipse application that tests some of my code.
>> b) Save it
>> line), then after a while I get a dialog "Agent Controller is
>> unavailable under port 10006" with an exception:
>> [.. stack trace ..]
>> closing the other one): "An unexpected error occurred while attempting
>> to establish a connection with the JVMTI agent.
>> Shown stack trace:
>> at
>> at
>> at
>> at
>> at
>> 5) Cry.
>> Can anyone help?
>> Please!
>> Joerg
FUDForum. Page generated in 0.03286 seconds
