Home » Archived » Test and Performance Tools Platform (TPTP) » "IAC was not found"
"IAC was not found" [message #127880] Thu, 03 April 2008 15:07 Go to next message
Dennis Forcier is currently offline Dennis ForcierFriend
"Integrated Agent Controller(IAC) was not found. Make sure you have IAC
installed."
Eclipse 3.3.1.1 (Windows)
TPTP Platform 4.4.100..
JRE 1.5.0.14
Everything freshened through Software Updates yesterday.
There is no other Agent Controller running.
Security is Off.
I don't see IAC listed as an item in the About Features list. Is it
supposed to be there?
I did get one of these (nested): "Agent Controller is unavailable under
port 10002. Make sure that the service is started and the port number is
correct under preferences."
The nested exception was: AgentControllerUnavailableException: Error:
Unable to connect to the Agent Controller.Connection refused: connect
Connection refused ???
I tried disabling Start/stop in Preferences to force it to run at
Workbench starup, but that didn't make any difference.
This is the first time I've tried to use Profiling on this installation,
so I can truthfully say that it's never worked.
Does IAC run as a Windows service?
Where should I look to confirm installation?
Re: "IAC was not found" [message #127909 is a reply to message #127880] Thu, 03 April 2008 17:47 Go to previous messageGo to next message
One other oddity: I brought up the workbench with IAC Start/stop Disabled
in Preferences. When I try to set it Enabled I get this error:
"AC home is null. Didn't generate config file"
Something really does seem to be fubar. I don't see this or the
'Connection refused' symptom mentioned in the '..not available on
localhost:10002' Bug description.
Re: "IAC was not found" [message #127935 is a reply to message #127909] Fri, 04 April 2008 15:09 Go to previous messageGo to next message
Holger Machens is currently offline Holger MachensFriend
Member
Hi Dennis,
I had similar problems on Windows XP Eclipse 3.3.2, TPTP 4.4.1.
My workaround is: Start Workbench (or at least the Agent Controller) as
administrator.
Greetings
Holger
> Disabled in Preferences. When I try to set it Enabled I get this error:
Re: "IAC was not found" [message #127993 is a reply to message #127935] Fri, 04 April 2008 22:39 Go to previous messageGo to next message
Thanks for the suggestion, but I already have administrator privileges.
Re: "IAC was not found" - [message #128031 is a reply to message #127993] Sat, 05 April 2008 20:39 Go to previous messageGo to next message
Richard Adams is currently offline Richard AdamsFriend
Member
I have the same problem too (no agent controller found), running Windows
XP, Java1.6, Eclipse 3.3.1.1.
Its pretty disappointing as so much of the profiling and testing depends
on the agent controller. Does it make any difference to download the zip
and install
directly rather than from the update site?
Re: "IAC was not found" - [message #128173 is a reply to message #128031] Tue, 08 April 2008 13:13 Go to previous message
Asaf Yaffe is currently offline Asaf YaffeFriend
> zip and install
Please seem some recent posts in this newsgroup suggesting that there
*is* a difference.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Previous Topic:An error occurred while attempting to resolve the data collectors selected
Next Topic:Can't get profiling to work
Current Time: Tue Apr 16 05:40:36 GMT 2024
Powered by FUDForum. Page generated in 0.16584 seconds
