Home » Archived » BIRT » New User :)
New User :) [message #930723] Tue, 02 October 2012 15:24 Go to next message
Ignacio Rodriguez is currently offline Ignacio RodriguezFriend
I'm new user of Birt, and I'm tried to use Birt for one app, I write the steps:
- I have installed the version eclipse complet (All in one).
- Then I have downloaded my app of the cvs, in this app, I have the reports and web app too.
- The report was been done with 3.2.17 versión, my versión of birt is 3.2.23, I don't know if this will have problems.
My problem is that when I go to report designe perspective, and I have tried launch a report (click botton right and then Run reprt), appear the following error:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at sun.jdbc.odbc.JdbcOdbcDriver.getProtocol(Unknown Source)
at sun.jdbc.odbc.JdbcOdbcDriver.knownURL(Unknown Source)
at sun.jdbc.odbc.JdbcOdbcDriver.acceptsURL(Unknown Source)
at java.sql.DriverManager.getDriver(Unknown Source)
Thanks in advance!!
Re: New User :) [message #930870 is a reply to message #930723] Tue, 02 October 2012 18:15 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
That error looks like you have not added the jdbc driver to the datasources. Create a new data source and select jdbc data source, click next then click on manage drivers button. Add the appropriate jar.
Jasojn
Re: New User :) [message #931541 is a reply to message #930870] Wed, 03 October 2012 09:51 Go to previous messageGo to next message
Hi, but the driver is correct, and my problem is the same. Sad
Re: New User :) [message #931565 is a reply to message #930870] Wed, 03 October 2012 10:17 Go to previous messageGo to next message
Could be possible that the problem to be the version of birt?
Re: New User :) [message #931603 is a reply to message #930870] Wed, 03 October 2012 10:49 Go to previous messageGo to next message
Hi!!
Now I'm copy the jdbc driver, and know the exception is:
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, The url cannot be null. (Element ID:2761)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1216)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:258)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:262)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:86)
at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1325)
at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtChangeParameterActionHandler.runReport(BirtChangeParameterActionHandler.java:58)
at org.eclipse.birt.report.service.actionhandler.AbstractChangeParameterActionHandler.__execute(AbstractChangeParameterActionHandler.java:53)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleChangeParameter(BirtDocumentProcessor.java:100)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1002)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:585)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1813)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:644)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:83)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 73 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:54)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:177)
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:224)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:212)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:217)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:407)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:317)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:624)
... 78 more
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, The url cannot be null.
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doConnect(JDBCDriverManager.java:211)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getConnection(JDBCDriverManager.java:168)
at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUrl(Connection.java:179)
at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connection.java:136)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:250)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:165)
... 88 more
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, The url cannot be null. (Element ID:2751)
... 73 more
... 78 more
... 88 more
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, The url cannot be null. (Element ID:2819)
... 73 more
... 78 more
... 88 more
exception.error
Error happens when create hierarchy:Empresa.NewTabularHierarchy.
Failed to prepare the query execution for the data set: documentos
Failed to prepare the following query for the data set type (org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet).
[select FILA, EMPRESA, sum(F_DOC_DOC_NUMBER) as F_DOC_DOC_NUMBER, f_doc_time_id, D_MYT_CUSTOMS_DES, fecha from ( select TORDEN.FILA, b.D_ORG_DESC EMPRESA , F_DOC_DOC_NUMBER , f_doc_time_id , D_MYT_CUSTOMS_DES , SUBSTR(d.D_TIM_MONTH_DESC,0,3) || || SUBSTR (d.D_TIM_YEAR,3,2) fecha from DWH_F_DOCUMENT a, DWH_D_ORGANIZATION b, DWH_D_MESSAGE_TYPE m, DWH_D_TIME d, (SELECT ROWNUM AS FILA, EMPRESA, TOTAL FROM (select a.F_DOC_RECIVER_ID EMPRESA , Sum(F_DOC_DOC_NUMBER) TOTAL from DWH_F_DOCUMENT a where a.f_doc_time_id >= 2 and a.f_doc_time_id <= 36 and a.F_DOC_RECIVER_ID in ( select D_ORG_COL_ORG_ID from DWH_D_ORG_COL where D_ORG_COL_COL_ID = 2 /* Transitario */ ) AND a.F_DOC_MSG_TYPE_ID in ( select D_MTY_MTY_ID from DWH_D_MESSAGE_TYPE where (D_MYT_MTY_NK = COREORI03 or D_MYT_MTY_NK = COPARNE02) and D_MYT_CUSTOMS_ID in (1) ) group BY A.F_DOC_RECIVER_ID ORDER BY TOTAL DESC) /*WHERE ROWNUM <11*/ ) TORDEN where a.F_DOC_RECIVER_ID = b.D_ORG_ORG_ID AND TORDEN.EMPRESA = a.F_DOC_RECIVER_ID and a.f_doc_time_id = d.d_tim_tim_id and d.d_tim_tim_id >= 2 and d.d_tim_tim_id <= 36 and a.F_DOC_RECIVER_ID in ( select D_ORG_COL_ORG_ID from DWH_D_ORG_COL where D_ORG_COL_COL_ID = 2 /* Transitario */ ) and a.F_DOC_MSG_TYPE_ID in ( select D_MTY_MTY_ID from DWH_D_MESSAGE_TYPE where (D_MYT_MTY_NK = COREORI03 or D_MYT_MTY_NK = COPARNE02) and D_MYT_CUSTOMS_ID in (1) and a.F_DOC_MSG_TYPE_ID = m.D_MTY_MTY_ID ) ORDER BY TORDEN.FILA ) group by FILA, EMPRESA, f_doc_time_id, D_MYT_CUSTOMS_DES, fecha ]
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Error preparing SQL statement.
SQL error #1: Syntax error: Encountered "ORDER" at line 1, column 902.
java.sql.SQLSyntaxErrorException: Syntax error: Encountered "ORDER" at line 1, column 902.
[select FILA, EMPRESA, sum(F_DOC_DOC_NUMBER) as F_DOC_DOC_NUMBER, f_doc_time_id, D_MYT_CUSTOMS_DES, fecha from ( select TORDEN.FILA, b.D_ORG_DESC EMPRESA , F_DOC_DOC_NUMBER , f_doc_time_id , D_MYT_CUSTOMS_DES , SUBSTR(d.D_TIM_MONTH_DESC,0,3) ||' ' || SUBSTR (d.D_TIM_YEAR,3,2) fecha from DWH_F_DOCUMENT a, DWH_D_ORGANIZATION b, DWH_D_MESSAGE_TYPE m, DWH_D_TIME d, (SELECT ROWNUM AS FILA, EMPRESA, TOTAL FROM (select a.F_DOC_RECIVER_ID EMPRESA , Sum(F_DOC_DOC_NUMBER) TOTAL from DWH_F_DOCUMENT a where a.f_doc_time_id >= 2 and a.f_doc_time_id <= 36 and a.F_DOC_RECIVER_ID in ( select D_ORG_COL_ORG_ID from DWH_D_ORG_COL where D_ORG_COL_COL_ID = 2 /* Transitario */ ) AND a.F_DOC_MSG_TYPE_ID in ( select D_MTY_MTY_ID from DWH_D_MESSAGE_TYPE where (D_MYT_MTY_NK = 'COREORI03' or D_MYT_MTY_NK = 'COPARNE02') and D_MYT_CUSTOMS_ID in (1) ) group BY A.F_DOC_RECIVER_ID ORDER BY TOTAL DESC) /*WHERE ROWNUM <11*/ ) TORDEN where a.F_DOC_RECIVER_ID = b.D_ORG_ORG_ID AND TORDEN.EMPRESA = a.F_DOC_RECIVER_ID and a.f_doc_time_id = d.d_tim_tim_id and d.d_tim_tim_id >= 2 and d.d_tim_tim_id <= 36 and a.F_DOC_RECIVER_ID in ( select D_ORG_COL_ORG_ID from DWH_D_ORG_COL where D_ORG_COL_COL_ID = 2 /* Transitario */ ) and a.F_DOC_MSG_TYPE_ID in ( select D_MTY_MTY_ID from DWH_D_MESSAGE_TYPE where (D_MYT_MTY_NK = 'COREORI03' or D_MYT_MTY_NK = 'COPARNE02') and D_MYT_CUSTOMS_ID in (1) and a.F_DOC_MSG_TYPE_ID = m.D_MTY_MTY_ID ) ORDER BY TORDEN.FILA ) group by FILA, EMPRESA, f_doc_time_id, D_MYT_CUSTOMS_DES, fecha ]
java.sql.SQLSyntaxErrorException: Syntax error: Encountered "ORDER" at line 1, column 902. (Element ID:1)
at org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorContext.executeQuery(ExecutorManager.java:451)
at org.eclipse.birt.report.item.crosstab.core.re.executor.BaseCrosstabExecutor.executeQuery(BaseCrosstabExecutor.java:122)
at org.eclipse.birt.report.item.crosstab.core.re.executor.CrosstabReportItemExecutor.execute(CrosstabReportItemExecutor.java:102)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:62)
exception.error
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteCube(DteDataEngine.java:233)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteCube(DataGenerationEngine.java:96)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:272)
at org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorContext.executeQuery(ExecutorManager.java:441)
... 75 more
Caused by: org.eclipse.birt.data.engine.core.DataException: exception.error
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.materializeCube(DataRequestSessionImpl.java:773)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:633)
... 79 more
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: Error happens when create hierarchy:Empresa.NewTabularHierarchy.
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimension(DataRequestSessionImpl.java:1466)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimensions(DataRequestSessionImpl.java:1325)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.createCube(DataRequestSessionImpl.java:824)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.materializeCube(DataRequestSessionImpl.java:765)
... 80 more
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: Failed to prepare the query execution for the data set: documentos
at org.eclipse.birt.report.data.adapter.impl.DataSetIterator.executeQuery(DataSetIterator.java:88)
Re: New User :) [message #931833 is a reply to message #931603] Wed, 03 October 2012 15:14 Go to previous messageGo to next message
Can you post the report? According the error you did not put a url in for the jdbc data source.
Edit the data source (not the data set) and verify that the url is set.
Jason
  • Attachment: dburl.png
    (Size: 60.14KB, Downloaded 384 times)
Re: New User :) [message #940093 is a reply to message #931833] Thu, 11 October 2012 09:59 Go to previous messageGo to next message
Hi Jason,
Yo was in the correct, the problem was the driver, but know I hve another problem...
I launch the report in the server all is correct, but if I launch the report in my local host to appear this error:
Cannot get the result set metadata.
SQL statement does not return a ResultSet object.
SQL error #1: ORA-00936: falta una expresión
An the database is the same!!
Thanks !!
Re: New User :) [message #941657 is a reply to message #940093] Fri, 12 October 2012 19:00 Go to previous message
Do you mean you try to deploy the report to the Viewer and it does not work? Make sure the driver is also in the Viewer's WEB-INF/lib directory.
Jason
Previous Topic:MS Excel data connection to BIRT report not working => SOLVED!!
Next Topic:Resize page footer dynamically (based on current page number)
Current Time: Tue Mar 28 22:42:07 GMT 2023
Powered by FUDForum. Page generated in 0.01662 seconds
