Home » Archived » Test and Performance Tools Platform (TPTP) » HTTP Recording stops immediately after start-up (FireFox) or never records data (IE)
HTTP Recording stops immediately after start-up (FireFox) or never records data (IE) [message #127053] |
Thu, 20 March 2008 10:19 |
Originally posted by: mshekov.gmx.de
I just installed TPTP using the Update-Manager (Version 4.4.1). I am using a
recent Eclipse Version on Windows XP Pro. I created a servlet-Webapplication
which is deployed on a JBoss application server (I am using the JBossIDE
plugin), it runs on localhost:8080.
I then right-clicked on the project that contains the servlet sources and
created a new "HTTP Recording" test.
However, I am not really able to test this feature. When I started this for
the very first time I had to accept some warnings from the integrated
Windows firewall (I approved all requests, so that no ports should be
blocked). However, the recording stops immediately after it started. This is
the output of the "Recorder control" view:
- Recording started
- Connecting to agent controller on host 'localhost' and port '10002'
- Deploying required recorder files
- Sending commandInit
- Sending commandStartRecording
- Sending commandStartApp Firefox
/* for one second nothing happens */
- Recording completed
- Testgeneration started
There are no recorded HTTP requests, as the plugin didn't even try to record
anything. Note that this only happens when using Firefox.
When I then setup TPTP to use InternetExplorer 7 I get another problem. With
IE the Recorder control view behaves properly in a sense that after "Sending
commandStartApp..." it actually waits for input. However, even if I then
visit the Servlet-Page using that IE window that was opened, it won't record
my GET-Requests ("KBytes recorded" stays at 0 all the time).
Ideas ?
Kind regards,
Marius Shekow
Re: HTTP Recording stops immediately after start-up (FireFox) or never records data (IE) [message #127293 is a reply to message #127204] |
Tue, 25 March 2008 16:15 |
Hello again,
About the firefox issue: the URL is setup correctly (and also the Firefox
application was started) but the problem remains the same.
I then had a closer look about what the Internet Explorer is doing.
Apparently one cannot tell the Internet Explorer (or better: the Microsoft
Windows Update Tool, as it doesn't serve any other purpose for me) to use a
proxy whatsoever on this machine. I was having a look at the network
activity (I did see that port 1090 was opened by the java-process, listening
for incoming connections). The Internet explorer never connected to it, even
tho I setup every f*cking protocol to use it, hehe. But then I opened also
the Firefox (manually) while keeping the IE open (in order to let the
recorder running). Then I manually setup the same local proxy in Firefox and
tried to open the URL which should be tested. This time it was able to
establish a connection, but I never got any output (TCPView told me the
connection had the status "ESTABLISHED", but that's about it, nothing else
happened). I have no idea why the proxy won't give me the output.
Kind regards,
Marius Shekow
Re: HTTP Recording stops immediately after start-up (FireFox) or never records data (IE) [message #131862 is a reply to message #127053] |
Fri, 27 June 2008 15:42 |
DuWayne Morris Messages: 36 Registered: July 2009 |
Member |
Sorry for the late reply.
Let's break this up into 3 issues and tackle each one separately:
1. Basic ability to record.
2. Recording the desired application.
3. The Firefox recording problem.
Do not modify any of the IE proxy settings. When the recorder starts and
the socks proxy is set, all traffic is routed there. By default, this
will be on port 1080.
Select Internet Explorer for recording. Browse to some outside web site
such as Google or eclipse.org for a couple of pages. See that you get
data recording and a URL Test is generated when you stop the recording.
There is a known problem in our release notes with Internet Explorer
recording traffic to a server on the local machine. IE knows the
destination is on the local machine, so it bypasses the proxy server.
(Also, make sure the "bypass proxy for local traffic is not checked in the
connection settings).
The work-around for this issue with IE recording is to substitute the host
machine IP address for the destination in your URL, such as
http://xxx.xxx.xxx.xxx/myhomepage.html when recording.
Bear in mind that if your application opens separate socket conversations
between the client and server without being directed to our proxy, that
traffic will not be recorded.
3. For the Firefox problem
I believe the settings have been mangled. Also, not sure what version you
are using. You may want to update to version 3 that was recently
released.
To correct the settings and hopefully get Firefox working with the
recorder, delete *.js under a user settings directory whose path is
something like this:
C:\Documents and Settings\username\Application
Data\Mozilla\Firefox\Profiles\xb81x7th.default
xb81x7th.default is a directory.
After deleting *.js, restart Firefox to initialize settings again. Close
Firefox and retry recording using Firefox.
Hope the above helps solve the problems.
Re: HTTP Recording stops immediately after start-up (FireFox) or never records data (IE) [message #131898 is a reply to message #131862] |
Tue, 01 July 2008 10:07 |
Originally posted by: manuel.weiss.stud.uni-due.de
I have have the same problem when i try to record with Firefox. I have
followed your advice and deleted the *.js files but it is still not
working. Do you have any other suggestions how to solve this problem?
Greetings,
Manuel
> and the socks proxy is set, all traffic is routed there. By default,
> this will be on port 1080.
> the connection settings).
> host machine IP address for the destination in your URL, such as
> conversations between the client and server without being directed to
> our proxy, that traffic will not be recorded.
> you are using. You may want to update to version 3 that was recently
> released.
> Close Firefox and retry recording using Firefox.
Re: HTTP Recording stops immediately after start-up (FireFox) or never records data (IE) [message #132002 is a reply to message #131898] |
Wed, 02 July 2008 11:27 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Manuel,
What are your symptoms? What version of TPTP and Firefox are you using?
Paul
"Manuel Weiss" <manuel.weiss@stud.uni-due.de> wrote in message
news:g4cvkd$pmt$1@build.eclipse.org...
> Hello,
> Greetings,
> Manuel
>> released.
Current Time: Sat Apr 20 00:24:02 GMT 2024
Powered by FUDForum. Page generated in 0.03604 seconds
