How to start bundles in proper order [message #929894] |
Mon, 01 October 2012 21:39 |
Mariusz Cwikla Messages: 15 Registered: January 2012 |
I have an issue with starting equinox application from Eclipse IDE. I can't get bundles to start in proper order. It seems that this error does not occur all the time. Sometimes when I create a new launch configuration and select all of the required bundles, I get application running correctly.
My test application uses Apache Aries. I have additionally two projects, one, that contains blueprint.xml that registers some objects in JNDI and second one is a test client. What I need is to start bundles in following order:
1. all of the required Equinox bundles
2. then Apache aries bundles
3. then my component with blueprint.xml
4. then my test application
Instead I have following order of bundles:
ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.8.0.v20120123-1419
2 ACTIVE org.eclipse.core.commands_3.6.0.v20111007-1312
3 ACTIVE org.apache.aries.jndi_1.0.0
4 ACTIVE org.eclipse.osgi.services_3.3.0.v20111117-1210
5 RESOLVED com.mc.logback.fragment_1.0.0.qualifier
Master=7
6 ACTIVE javax.jms_1.1.0.v200906010428
7 ACTIVE ch.qos.logback.classic_1.0.7
Fragments=5
8 ACTIVE ch.qos.logback.core_1.0.7
9 ACTIVE org.apache.aries.proxy_1.0.0
10 ACTIVE slf4j.api_1.6.4
11 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
12 ACTIVE org.eclipse.equinox.common_3.6.100.v20120120-1540
13 ACTIVE blueprint.jms.activemq.registration_1.0.0.qualifier
14 ACTIVE org.apache.activemq.kahadb_5.6.0
15 ACTIVE org.apache.aries.util_1.0.0
16 ACTIVE org.apache.activemq.activemq-core_5.6.0
17 ACTIVE org.apache.geronimo.specs.geronimo-jms_1.1_spec_1.1.1
18 ACTIVE org.eclipse.equinox.console_1.0.0.v20111215-1210
19 ACTIVE org.apache.geronimo.specs.geronimo-j2ee-management_1.1_spec_1.0.1
20 ACTIVE org.apache.aries.blueprint_1.0.0
21 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
22 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
23 RESOLVED blueprint.jms.activemq.test_1.0.0.qualifier
My component is inside blueprint.jms.activemq.registration_1.0.0 (id=13) and my test application is blueprint.jms.activemq.test_1.0.0 (23).
My test application should be registered by org.apache.aries.jndi (id=3) and org.apache.aries.blueprint (20), but my component is in the middle (13).
Right now I get some errors caused by not registering my component by aries properly.
When I "stop 13" & "stop 23" & "start 13" & "start 23" everything goes right.
I also tried to play with start levels (set start level for all apache aries to 3, my component to 4 and client to 5) but it did not solve the problem.
How can I force start order of my bundles inside Eclipse IDE (I use Run->Run Configurations->OSGi Framework)?
When I use Equinox standalone (directly from console, with config.ini) everything is ok.
[Updated on: Mon, 01 October 2012 21:40] Report message to a moderator
FUDForum. Page generated in 0.03042 seconds
