Context menu in custom widget [message #126558] |
Tue, 31 March 2009 11:46 |
Originally posted by: haglund86.hotmail.com
Hi!
I want to add a context menu to my custom widget. I've looked at
Qooxdoos example code for creating these menus, but I havent managed to
create one. Does RAP even have support for creating a context menu
inside a custom widget, and if it does, how do I create one? Thanks!
Re: Context menu in custom widget [message #126583 is a reply to message #126558] |
Tue, 31 March 2009 13:19 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Erik,
here is a small example:
1. add contextmenu listener to your JS client implementation
this.addEventListener( "contextmenu", this._onContextMenu, this );
2. use the code below to open the menu
_onContextMenu : function( evt ) {
var menu = this.getContextMenu();
if( menu != null ) {
menu.setLocation( evt.getPageX(), evt.getPageY() );
menu.setOpener( this );
menu.show();
evt.stopPropagation();
3. set the menu on the server side
Menu menu = new Menu( customWidget );
MenuItem menuItem = new MenuItem( menu , SWT.PUSH );
menuItem.setText( "Menu Item Text" );
customWidget.setMenu( menu );
4. Make sure that you call ControlLCAUtil#preserveValues and
ControlLCAUtil#writeChanges in your CustomWidgetLCA.
Best,
Ivan
Erik Haglund wrote:
> Hi!
> to create one. Does RAP even have support for creating a context menu
Re: Context menu in custom widget [message #126593 is a reply to message #126583] |
Tue, 31 March 2009 15:03 |
Hi Ivan and thanks for your reply.
I don't understand the last step:
Could you please explain this step a bit more?
//Erik
Ivan Furnadjiev skrev:
> Hi Erik,
> var menu = this.getContextMenu(); if( menu != null ) {
> menu.show();
> Best,
> Ivan
> Erik Haglund wrote:
>> Hi!
Re: Context menu in custom widget [message #126632 is a reply to message #126593] |
Tue, 31 March 2009 16:29 |
Hi Erink,
your custom widget have a LCA - CustomWidgetLCA. In the CustomWidgetLCA
in the method preserveValues call ControlLCAUtil.preserveValues(
customWidget ) and in the method renderChanges call
ControlLCAUtil.writeChanges( customWidget ). Take a look in some of the
existing RAP controls LCAs - ScaleLCA.java for example.
Best,
Ivan
> //Erik
>> Hi Erik,
>> menu.show();
>> Best,
>> Ivan
>> Erik Haglund wrote:
>>> Hi!
>>> menu inside a custom widget, and if it does, how do I create one?
>>> Thanks!
FUDForum. Page generated in 0.03250 seconds
