Re: Using multiple OutputConfigurations with an JvmModelInferrer [message #929494 is a reply to message #928660] |
Mon, 01 October 2012 13:56 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Boris,
I'd put an eAdapter into the inferred type to indicate the output config
and read that one from a subclassed JvmModelGenerator in order to direct
the file into the right directory.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 30.09.12 14:37, schrieb Boris Brodski:
> Hello,
> I would like to have multiple outlets (IOutputConfiguration) and choose,
> which classes goes in which outlet. This was possible with the
> IGenerator approach, but seams to be complicated with the new
> JvmModelInferrer approach.
> Use case example:
> Generation of abstract classes is more user friendly, if the standard
> implementations are also generated but only once. (Output directory:
> "src", override: false)
> Thank you!
FUDForum. Page generated in 0.03048 seconds
