Several questions about LDT [message #927939] |
Sun, 30 September 2012 05:44 |
Denis Artemov Messages: 38 Registered: September 2012 |
Member |
I'm trying LDT right now (0.8 and 0.9 versions). Can't make outlining working. It shows only local variables. How to make it to show more members?
Also if to add any russian comment or text into source, variable highliting, syntax coloring, code assistant become broken. How to fix it?
And how to make code folding to work? It sometimes shows (-) for folding randomly in sources, but folds erroneous block if to click on (-).
PS: Sorry for my English
PPS: standalone LDT 32 bit 0.8 and 0.9
[Updated on: Sun, 30 September 2012 06:25] Report message to a moderator
Re: Several questions about LDT [message #932835 is a reply to message #930542] |
Thu, 04 October 2012 13:34 |
Simon Bernard Messages: 345 Registered: July 2009 |
Hi Denis,
I have some precision/correction about your problems :
1) We currently (v0.8.x) don't support UTF8 encoding, we only support ascii (one byte character exactly).
2) As you found by yourself, all problems about syntax coloring, variables highlighting and folding come from non ascii character in your source file. If you want to follow this problem, a bug is opened.
As you could see, it's a serious problem and we plan to fix it for the v0.9.0, but we did not found a good solution for now.
Your proposition is interesting but this means if there are non ascii character in code, outline content-assist and documentation will contains "?" char instead of the right one :/.
If we don't find a better solution, this could be the lesser evil.
Thx denis for your feedback and the code you post.
Re: Several questions about LDT [message #949128 is a reply to message #948704] |
Thu, 18 October 2012 18:18 |
Member |
With "mvn clean install -P build-product" it stops on
[INFO] org.eclipse.koneki.ldt.metalua.tests .............. SUCCESS [12.808s]
[INFO] org.eclipse.koneki.ldt.core.tests ................. SUCCESS [14.976s]
[INFO] org.eclipse.koneki.ldt.ui.tests ................... FAILURE [13.837s]
[INFO] org.eclipse.koneki.ldt.product-product ............ SKIPPED
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 4:24.857s
[INFO] Finished at: Fri Oct 19 00:16:07 YEKT 2012
[INFO] Final Memory: 90M/237M
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:0.15.0:test (default-test) on project org.eclipse.koneki.ldt.ui.tests:
There are test failures.
[ERROR]
[ERROR] Please refer to D:\java\LDT\tests\org.eclipse.koneki.ldt.ui.tests\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
[Updated on: Thu, 18 October 2012 18:19] Report message to a moderator
FUDForum. Page generated in 0.05503 seconds
