Home » Modeling » BPEL Designer » ExtensionPoint for Tabbed Properties question
ExtensionPoint for Tabbed Properties question [message #11560] Sun, 22 March 2009 16:01 Go to next message
Christian Fonden is currently offline Christian FondenFriend
I recently created some ExtensionActivity elements for BPEL and have
successfully imported them into the eclipse BPEL designer.
Also, adding them to the palette was no problem.
Now I want to be able to change some properties of that extension activity
objects. To do so, I planned to extend the
org.eclipse.ui.views.properties.tabbed.propertyTabs / propertySection
extension points of the BPEL Designer.
Now, when I deploy the plugin and load an BPEL File into the BPELEditor,
nothing is added to the properties view (no tabs, now sections).
As the documentation on the BPEL Designer Homepage is terribly out of date
(last change 2005!!!), I'm asking here in this newsgroup for help.
What am I doing wrong? Any help is appreciated.
greets
Chris
Re: ExtensionPoint for Tabbed Properties question [message #11739 is a reply to message #11560] Fri, 17 April 2009 17:13 Go to previous messageGo to next message
anyone here?
Re: ExtensionPoint for Tabbed Properties question [message #479473 is a reply to message #11560] Tue, 11 August 2009 09:43 Go to previous message
Lukasz Dywicki is currently offline Lukasz DywickiFriend
Member
May you try Equinox Aspects?
Luke
Previous Topic:Eclipse 3.5 -> javax.wsdl 1.5
Next Topic:Invoking Drools Rules Engine from GMF
Current Time: Thu Oct 06 00:13:55 GMT 2022
Powered by FUDForum. Page generated in 0.01996 seconds
