RAP support for other Eclipse bundles [message #125931] |
Mon, 23 March 2009 13:04 |
Originally posted by: Florin-Alexandru.Bratu.sophia.inria.fr
Hello!
My scenario is the following: I have an Eclipse RCP application, and I
would like to port it for the Web. I found out about RAP which promises
to being able to do it without actually rewriting the interface code. So
I gave it a shot but apparently it is not that easy - like it never is! :D
The problems I get are mostly related to the fact that RAP(in fact RWT)
implements a subset of the SWT functionality, not all. Also, the
problems with using other bundles with RAP are not fully solved.
My question is the following:
- is there a description of the features from SWT that are done in RWT
and the ones that are still missing(something like a TODO plan) ?
- is there a list of the Eclipse bundles that are supported by RAP, and
those that are not yet supported?
All I found is:
http://www.eclipse.org/projects/project-plan.php?projectid=t echnology.rap
but I this document does not provide all the information I need.
Re: RAP support for other Eclipse bundles [message #125955 is a reply to message #125944] |
Mon, 23 March 2009 15:05 |
Ivan Furnadjiev wrote:
> Hi Florin-Alexandru,
> in general we use the presumption of compile-error (all missing features
> in RAP will give you a compile error).
Not too practical approach because I get about 6000+ errors...
> About the supported Eclipse bundles - look at the RAP target platform [2].
10x for the tip, this helped!
> Best,
> Ivan
Florin.
Re: RAP support for other Eclipse bundles [message #126262 is a reply to message #126250] |
Wed, 25 March 2009 19:32 |
Sorry for the late reply. In the meanwhile, I tried a different
approach: javaws'ing my RCP plugin...
Rüdiger Herrmann wrote:
> Florin,
> 6000+ errors sound a lot. Did you change the dependencies from
> org.eclipse.ui to to org.eclpse.rap.ui?
yap.
> Are you aware of the single sourcing webinar [1]?
Nope. Watching it right now...
> HTH
> Rüdiger
> [1] http://www.eclipse.org/rap/singlesourcing.php
FUDForum. Page generated in 0.03202 seconds
